Rebuilding my M5OD-R1 99 Ford Ranger Transmission
Today was a good day! The old clutch is off, as well as the flywheel. I was able to replace the rear main seal. I know very little about this stuff but I think the old seal was fine, and the oil pan gasket is seeping. I could certainly be wrong, but some time after all the transmission stuff is done, I may replace the oil pan gasket.
The pilot bearing is pretty stuck in place. I tried the hydraulic method, and some other things to get it out without destroying it. Long story short, it's destroyed but still stuck. Ran out of time today, but I'll get it another time.
The old clutch plate has worn away its grooves, but has not yet reached the rivets. Just for fun I compared the thicknesses. The new plate measured 8.2mm, and the old plate measured 6.7mm. Doesn't seem like much, but I'm glad I'm replacing it anyway.
The flywheel and pressure plate friction surfaces look clean and uniform. No bluing from excessive heat. A new pressure plate came with the kit, so I'll replace it anyway.
Sounds like the pilot is in the crankshaft, once the rollers are out of the way I've taken a dremel and gone at one wall carefully until I got through then drove a fine pin (or hard nail) at the seam to break that and pull it out.
I took the transmission back apart today, getting ready for the arrival of the rebuild kit. Looking over the documentation again, there is info on the orientation and assembly of all the parts of the synchronizers. I'll be paying close attention to that when I put all the new parts in. For now, they're all working well off the shaft.
Also in the picture are the old rear main seal off the engine, and the idler gear assembly, which I found out can be removed as a single piece from the transmission. I used the sheet metal screw method to get the old seal out. Worked great, though the head of the screw broke off right as the seal was coming out.
Another question for you guys: The two big nuts in the rear of the shafts; do I need to replace them? It seems that I'm officially supposed to according to the documentation. But I've also heard that they can be reused as long as they can be re-peened after torquing. Also, how does one even torque the larger one on the output shaft? I suddenly have this vision of putting a hanging scale on the end of a pipe wrench, LOL.
Another good day! There was a bit of good weather, and I got the pilot bearing replaced. I remembered I bought a pilot bearing puller years ago for some other project. It would have been too big for the Ranger's pilot bearing, but at some point I'd ground the hooks down to fit a smaller diameter bearing. Pulled it right out.
Rebuilding my M5OD-R1 99 Ford Ranger TransmissionRebuilding my M5OD-R1 99 Ford Ranger Transmission
So that's the engine done and ready for the flywheel. I went inside to search for the torque specs for the flywheel nuts (60 ft-lbs) but before I could go back out to work the weather turned on me again. Meh. Another day.
More good news: my rebuild kit arrived early. Turns out I may as well have ordered the one without syncro blocking rings. Mine were all well within spec. And the kit didn't come with a 3rd gear ring anyway. I could have saved a bit of money. Oh well. After having triple checked the hub and sleeve assemblies, I got the shafts together and back in the transmission.
I've gone ahead and installed all the new bearings. I cut the bearing cage off one of the tapered bearings and used the inner race to press on the new tapered bearings. At this point I'm supposed to measure the shafts for end play. I think I'm doing it wrong. For the counter shaft I measured 1.4mm the way the instructions said, but after putting the retainer plates on, there is no end play at all. For the main shaft I measured 1mm the way they said, but I've got about half of a mm after the endplates are installed. What I've read is that there is supposed to only be 0.15mm or so. Not sure how to proceed.
My calipers may not be precise enough for this. I have a micrometer, but it's missing it's depth gauge.
I decided to stop for today and do some searching.
View attachment 137420View attachment 137421
Thank you for posting all this. I plan on doing this project in the spring/summer and all of this is very helpful.
As far as I've heard the important part is the preload on the tapered bearings so assemble things without any shims and check end play then shim for ~0.003" or thereabouts of preload.
Thanks. I've also been reading that the ideal endplay is 0 or even a tiny bit negative. I think the countershaft is ok since it doesn't move now, but I'll have to do something about the main shaft.
I did some searching and found one fellow on eBay selling E8TZ-7029-R spacers. The last letter indicates the thickness. My spacer is 3.4mm so it would be the K version. The R is 3.9mm so 0.5mm thicker. It looks like these are no longer produced, so I got lucky finding anyone with the right size. I suppose a person could make their own shim to augment the existing spacer if necessary. Hopefully I won't have to do that. It's gonna take 10 days to get here, so I guess I'll have to find something else to do until then.
Transpartswarethouse has the shift lever dust cover and the shaft nut set for a reasonable price, so I'll go ahead and order those now. I think (hope) that that is the last of the stuff I'll need to buy. Except a tube of gasket/sealer for the parts that need it.
By the way, Pacstud, I got the bearing puller at Harbor Freight. I don't think it was very expensive. I did have to grind it down a bit to fit the Ranger's pilot bearing.
I was going to mention that I think I reused the nut when I did my rebuild, although it's not correct it works fine...
You can get creative with the shim if you need to, finding thin stainless is hard and I don't think beverage cans being aluminum is ideal for that purpose... :) There's likely a source of thin stainless but it's not coming to me right now... when I was shimming my ZF5 I asked my transmission rebuilder friend and he handed me a couple and I just took tin snips and made what I needed...
I've been thinking of replacing the oil pan gasket. It appears to be seeping, and the whole pan is covered in oil. I thought it would be a future project but looking into it, it looks like to get it off, lots of other things must be moved out of the way. Or the engine has to be removed (according to the shop manual.)
Since I'm this far into it, I guess I might as well do this now too. Here's the best video I've found so far:
There are differences because this one's an automatic, but I think that actually simplifies a few things. Also I'd love to see how much sludge is in my pan after 200,000 miles. (And remove it.) In another video, a fellow used a bottle jack to lift the engine to make more room for the oil pan.
Curiously, some folks use RTV to glue the gasket to the pan, and some don't use any. Opinions?
More parts came in ahead of schedule. Including the new 3.9mm spacer. Still wasn't enough to eliminate end play, so I found a sheet of aluminum 0.7mm thick, and made a shim. That and the new spacer was enough to remove the end play. I guess my original measurements were pretty close after all. I had measured 1mm according to the documented procedure, and I added about 1.1mm to get rid of the endplay. The countershaft has a tiny bit, but I'm not going to bother since it's so small it doesn't show up on my caliper. So the front of the transmission is finally done.
Tomorrow (or later today I guess) the weather is supposed to be good. Maybe I'll get the clutch installed.
I continued reassembly today. I've gotten to the part where the nuts go on the output and counter shafts. I was able to torque the small nut to 85 ft-lbs. That's as high as my torque wrench goes. The spec is something like 94-114. The output shaft nut is supposed to be torqued to over 100 ft-lbs. I have no way to do that. I don't even have a wrench that will fit it. I used a pipe wrench to get the old one off.
I've been watching reassembly videos. They either gloss over the fact that you're supposed to torque them, without actually torquing them, or they just get them generally tight with a regular wrench (or in the case of one guy, a hammer and chisel). What do you guys do?
Yeah, roughly that, I have a big 24" adjustable wrench from Harbor Freight and just wing it... maybe hit that wrench with a hammer a couple times to make sure it doesn't move... staking it afterwards pretty much makes sure it can't back off which is the worst case scenario...
Lots of things have torque specs that are ignored. Especially when working on your own stuff. When's the last time you torqued lug nuts at home? I tried it once, then went back and tightened them. Spec is scary loose. 90FT-LBS
So make it as tight your lug nuts and you'll be fine.
First time working on a new mazda 3 (2011, basically a focus) and the lugs are 86 ft/lbs!
