BW1354/1354 Doubler
I'm too lazy too read everything....
but I used a regular cab tank in place of my SuperCab (1995) tank when I put the doubler in. I also trimmed/reworked the tank skid plate mount around the front mount. It gets into the driveshaft still when the truck is all twisted up. It was also an issue before the doubler when I went to the one piece rear shaft.
Also I was told or read years ago the 6 gear planetary was for NVH (Noise, Vibration, and Harshness) issues not actually a strength problem.
I'd have to look at my 97 Single Cab Shorty and see if the tank would clear or not.
The only issue I see with swapping or adding a Bronco II tank on a Ranger is the issue of the fuel tank hanging down below the frame. So, you would lose departure angle. Adding a skid plate to protect the tank would execerbate the issue.
The bigger fuel capacity would be nice. If I remember correctly, BII tanks are 23 gallons where as the original second tank on the Rangers were 13 gallons.
Bronco II did have a 23 gallon tank
What??
The 1989 and 1990 pdfs open for me, and when I clicked and saved the 1990 pdf it was 291 MB.
It just takes long for the information to get to CA. 🤷‍♂️
You're only looking at the Windows (always-erroneous) reported file size...
The actual file size is the figure next to it in bytes:
BW1354/1354 Doubler
(the 1989 file is 377,428,383 bytes).
Most .pdf files of this type are 1.5 to maybe 5MB, so is why I was taken aback by those filesizes and their (nearly 1-minute) load times. Mostly I mention it for the sake of those who are on mobile or satellite data connections (luckily I was on my household cable connection).
Alright, carry on then...
I have no way to change their file size. Sorry.
Yeah, changing file sizes on PDF's is a pain, I've managed once but I don't remember how... I can't wait until I can get some more modern internet speeds at home, this .75-1.5 mpbs is useless on modern internet use... basically like the old 28k modem days! Should have fiber by spring though...
This thread got motivated to stock up on 1354M cases lol
Snagged this today... willing to trade for a 93-97 setup, but it will work in pinch.
BW1354/1354 Doubler
BW1354/1354 Doubler
