What did YOU do today?
im towing a 1500lb trailer, 500lb in the bed, about 500miles.
2.5l mt 2wd yr2000
staying between 4th gear 54mph on flats and 3rd gear 41mph on inclines.
...2nd gear, 30mph over mountains.
seems like sometimes i get stuck between between 3rd gear at 3300rpm and 30% 'load' or 4th gear 2200rpm and 60% 'load'.
which is worse for truck? high revving or lugging engine? i try not to do either for extended periods of time
Transmission wise 4th gear is best as it is least amount of load on it, the engine doesn't care either way and at those engine speeds you aren't going to notice a fuel mileage difference, throttle response wise I would favor more engine speed... I mean cruising flats go for low engine speed and downshift when power is needed...
Well, F-150 got a new U-joint in the front axle (the old one was quite crunchy) and I topped off the transfer case. There’s still a big list for that truck and I could use some new axle seals as I found out today, but the discovery of glitter in the t-case tells me that more work to that truck on things I don’t intend to reuse on the rebuild is pretty much throwing good money after bad. So, 4x4 is functional for a questionable amount of time. Emergency use only. On to the next thing.
Wish I could pick up something a little more solid for temporary use or even better a parts donor for the rebuild, but people have gone dumb and the price for a trashed OBS is stupid. I’m a little salty about the situation.
Well, the 2011 is down. I think it is a spark issue. It wants to try to start but can't quite get there. Once the rain stops, I'll start troubleshooting to narrow down what the issue is (spark, fuel, air) and then figure what is not working right.
Hopefully, it still won't start when I get at it. It's and intermittent issue and seems to fix itself if left alone long enough.
If by chance it does start, I'll leave it running so I can get it in the garage, out of the weather. The trailer suspension pieces and the saw horse table will have to be moved out of the way and the trailer parked out on the street.
So, the battery got replaced on the 2019 to make sure known problems with it are taken care of. The battery was down to 11.8 V after sitting for a while. So, it was definitely on its way out soon.
It would be nice if things would stay running long enough so I could put the carport up. Then there would be less need to shuffle things around in order to fix things when they do break.
Man, sounds like everyone is taking a beating lately
Well I'm glad I'm not the only one with that luck... the last several years I haven't been able to get far enough ahead to be considered behind... or something like that...
Got home a while ago with the sheetrock, grabbed a box of joint compound and a roll of paper tape. Heading out shortly to do something productive, maybe do the caulking around the plywood seams, I didn't grab any primer tonight, didn't want to waste too much of Jeff's time, we only got 50' into the store to get everything we got :). As with everything I do I'm winging it... youtube university and asking friends... Oh I did make the smart decision to put the drywall on sawhorses, easier all around, glad I made some not long ago...
2019 I believe. She doesn't want the 12-19, doesn't like the look. Wants the generation before, likes that it's more "bubbled". Looking at a 2008 with 36k. 2.5 liter (internet says it's the more durable of their engines).
Big thing is I'm going to get good at rebuilding/refinishing interior trim. Apparently European cars of the time us a "soft touch" coating that disintegrates/melts. Gonna be fun. Like most, maintenance keeps it going, neglect and they break. Has some "usual" weak points but nothing too catastrophic.
It's something to learn, so that's good. Most importantly, someone who really deserves to be happy will get something that should do it.
Go ritzy!!
But be careful what you wish for so you don’t get in mama‘s cross hairs! I’ve had every kind of exotic car, big truck, sports car, etc. you can imagine. I built this car as a joke about 15 years ago and sold it five years ago. Beyond the shadow of any doubt, it was the biggest chick magnet I ever owned. Big ones little ones short tall good looking old young ugly you name it, they would step off the curb and stick their head in the window when I stopped in a red light, flag me down on the road, wait by the car until I came out of the store. It was a trip! The designer only made 37 of the kits, and they only fit on a 1973 super beetle.
No go on the beetle. Popped an engine code (ignition coil/misfiring cylinder) during the test drive, but ultimately the wife didn't like the feel. So the quest continues.
I spent the past day and a half working on a closet… and it’s still not done. I have 5 more drawers to build.
This is only half the closet. I’m building a built in bench out of cedar on the other wall. I have it framed out, I just need the time to finish it.
I did some troubleshooting on the 2011. I make a thread in the engines section on the details.
I was awakened at 4 in the morning by someone in the parking lot of the hotel I was staying at in Klamath Falls, yelling, "Is anyone going to Portland? I need a ride to Portland!" After about 30 minutes of this someone who thought he was a tough guy started yelling back. I finally got up and drove to Medford where I had to do some work. After work I told my coworker we were going to eat at Black Bear Diner (the company paid for it). I waited for him to figure out how to get there. When he finally arrived he said he wanted to eat at a Dairy Queen across the street. I thought he was joking. Then he wanted to argue about which restaurant made fresh food. I finally told him I have the company credit card to pay for it and he should probably save the receipt if he wanted to expense it and get reimbursed. He drove off across the street to have a cold microwaved hamburger at Dairy Queen. I went into the Black Bear Diner and had a Western BBQ Burger.
Choosing to eat dinner at Dairy Queen instead of the Black Bear Diner really explains a lot about what it is like to work with him.
He later texted me asking if I-5 going through Medford is the same I-5 that goes through Sacramento. I couldn't be bothered to reply to that. I guess I'll find out on Monday morning if he didn't go the wrong direction on I-5 and drove up toe Eugene or Salem before he figured out he went the wrong way.
More leaves. More. Leaves.
I’m about sick of cleaning leaves out of my shop. Wind always seems to be blowing them in there
Event Coverage
TRS Merch
