Rough idle and intermittent stalling/ incomplete stall?
NaomiTheNomad
Forum Member
Florida
Just swapped in a rebuilt motor due to low compression and oil consumption on the last one. I sort of have an idea of what it is and it was a rebuild error on my part. New motor has about 5-6k on it, no oil issues or overheating or fluids mixing, HOWEVER, due to improper surface prep… i have coolant leaking from the edges of my head gasket.
Now i know, bingo there is your issue, head gasket, here is why i have been looking around though for something other than the head gasket, i dont have white smoke out the tail pipe or like i said, fluids mixing, or any overheating or bubbles in the coolant, but it still stalls. It was an issue with the last motor too, part of me thinks wiring, or maybe the last motor had a blown HG too.
thought cats for a little because i have a code for them but i stuck a scope down there and saw no cloggs in the honeycomb and the back pressure didnt go over 1 psi. So that was ruled out, checked out the wire on one of my fuel injectors because it was frayed, that checked out good, checked fuel pressure… 65psi, so that checked out. Im wondering if the head gasket could be the culprit for my stalling and rough idle, or wires. Torque converter also crossed my mind at some point, i don't think that would cause this specific set of symptoms though, i just need some second opinions from some other experienced folks here, cam syncro could be a culprit too, the ford one i installed had a slight squeak that went away as soon as the new motor was primed, there is no codes but p0420 and p0442. At the end of the day, head gasket is getting redone anyway, just thought it was a bit strange if it caused my stalling.
Does it stall when it's cold, or only after it's warmed up?
What happens when it's warmed up, and while the engine is running, you unplug the wiring plug to the idle control solenoid? Does it keep running or does it stall?
Usually when its warmed up, i also noticed in cold weather it idles better and in warm weather it idles like crap
Alright, did some tests today, including unplugging the IAC, that caused it to run a little worse, swapped it to an old one i had and replaced because it was carbed up. still ran worse, tested the resistance and the voltage and they checked out, also double checked voltage and resistance to fuel injectors and they checked good. So possibly a vaccum leak, smoke tests before showed no reaults
Did a compression test and we have a 30psi variation on three cylinders lowest reading was 130 highest was 160 on a cold engine,sitting and watching the numbers for a few minutes and they held well with not alot of visible leaking on the gauge. im hoping its that visibly leaking head gasket, i have no leak down tester. Also noticed today when i ran the engine it smells like exhaust, i just re did the exhaust gasket due to a leak but it had this stalling issue beforehand.
I dont think its valve seats or rings as they are brand new and i did a proper break in procedure, i do need to go back out and do a wet test to confirm its not rings but it got dark and the skeeters started hunting down blood
Any time I've made any kind of change in the intake sensors, (swap, clean, or repair connector) I have to clear the PCM memory then drive for about tank of gas before it learns to run right again.
Just a photo of the head gasket surface before i assembled the motor, looking back, yeah, that needed more surface prep… rookie mistake.
I'm impressed that you got the block in the seat...
Edited to add:
Also, WTF is that?
Event Coverage
TRS Merch
