33x12.50 tires
Corbin
KY - USA
Other
1975 Ford Bronco
Vehicle
Drive
2”
31x10.50
I have a 2000 Ranger super cab 4x4, I’ve leveled it and want to know if I can run a 15x8 wheel with 33x12.50 BF Goodrich K O’s
When you say “leveled” do you mean you cranked the torsion bars to level it?
We were going to try that on dad’s one Ranger but never got around to doing it. Might rub, might not.
What gears do you have? You’re going to want 4.10 gears for that. Or deeper.
Personally I’d throw a TransGo shift kit at that automatic transmission and a bigger trans cooler if you haven’t. And adjust the bands.
33x12.50 will rub bad (need a 4" lift for those).
You probably could do 33x10.50 though, depending on what your tolerance level is for rubbing... Having them on a set of OEM 15x7 alloys (or equivalent) should give you the least amount of rubbing (if it rubs, it should only be when the suspension is compressed hard and the wheel turned).
If you're on stock 16" wheels currently, 265/75R16 (equivalent to 32x10.50) should fit with no rubbing at all.
I put the torsion bars keys on it, but more or less I cranked the torsion bars up to level it. I have stock 15 in wheels with BF 31x10.50x 15’s on it. There is a lot of room. I’m putting 15x8’s on it. Approximately 3.5 back spacing
As 4x4junkie said, The12.5" wide tires will have serious rub. I tried 32x11.5-15 tires and they would rub a little mostly when off-road. I have been running 33x10.5 tires for many years and rarely get a very light rub off-road with some extreme articulation.
I have about a 1.5" torsion bar lift in the front and level it in the rear with assist air bags. I never have any rubbing in the rear. The rare light rubbing is in the front.
I have run 33x10.5 BFG MT KM3 and AT KO2 tires with no problems with rubbing.
Moving the tires out will make them move more as you steer. Making them wider basically moving them out farther too.
That's what I ran on my old 05 Sport Trac with just a torsion crank and they fit fine.
