My New House & Workshop
Well who would want to do it for free?
When I worked at a hardware store we had a counter thing you pulled wire/rope thru that measured the length automatically.
While you are having fun digging, put yourself a decorative post out there and install a motion light on it so it lights up when you pull up at night. You can feed it right out of the box with 3/4 conduit. Or use that flex that you are planning to take down and use it to feed the new pole light/protector.
I have a ring security light / camera by my back door that comes on when it detects motion and a solar one on the side of the shop. I plan on adding a light to the side of the shop to replace the solar one.
That flexible conduit has a junction box along its path and there's nothing behind it. I thought maybe something came out the back and into the house, but no.
There's no knockouts on the top probably because it's an outdoor breaker panel. All the knockouts are on the bottom. Cleaning this scrappy install will be a later project.
I have a ring security light / camera by my back door that comes on when it detects Eric and a solar one on the side of the shop.
FIFY
Sometime down the road when you want to feed out of the top of the panel, you can buy one of these. You can see that bump in the top middle of the panel now. You unscrew that and screw this piece on(hub). You just have to specify what size thread you want. You can probably easily find 3/4 threads, and use a short piece of 3/4 conduit. You need to figure out what brand panel you have also. Some of the hubs have 4 bolts, some 2 bolts. The below is a 2 bolt square D.
I used some electric tape and taped the wires together about every 14-16 inches (roughly) so I had a long tight harness.
I used the shop vac, plastic bag and string trick but actually never used the string. I was able to stand up on the ladder and shove the wire down through the conduit all the way to the pull box.
I used some Klein Tools Foam Wire Pulling Lubricant which I think helped a lot.
Once the cable got to the pull box I pulled it by hand. I just kept looping the other end up so it was pulling straight down and not of the edge of the LB.
I put yellow tape on the wire so I knew where to stop to leave enough room to go from the LB to the subpanel.
Now I have to go pull the wire from the pull box to the main. 💪😁
Uh oh. That was directional wire, and you pulled it from the wrong end I think.
Yup
Pull it on thru and then go back the other way with it or your lights will only put out darkness. :fie:
Looks good. Just don't forget the grey grease on the ends of the wires when you slip them in the terminals.
The second half didn't go as well.
There's (3) 45s and the 3rd 45 goes into a 90 degree sweep to the surface. On my 1st attempt it was going decent, and then it was like I ran into a wall and it wouldn't go anymore. I was going back and forth between pushing and pull the rope and the rope came off. So with probably 2-feet to go, I had to pull the wire out abd start over.
On the second attempt pulledcout 2x the length of rope, attached a bag in the middle, and pulled it through with the vac so I had double the line strength.
This time when I hid that spot I was able to push and pull inch by inch until it was finally through.
The pull box was a life saver. This job would have been impossible without it.
I also didn't have to go through that last 90 to the main panel. These last couple of pieces were dry fitted and I removed them so I could pull the way straight up out of the ground. I'll slide the pieces over the wire and cement them in place.
I also found that I over estimated how much wire I was going to need by a few feet. 🤷‍♂️
Excellent job. You did fine. The rest is easy.
I still need to find some lights for my shop. It had four old 8-foot fluorescent lights that I took down and trashed. I need to find some LED Lights to go back up.
Yes, I know I could have converted the old lights to LED, but they were really old and I didn't want to mess with them.
Good choice. Watch for 4ft led shop lights to go on sale at Lowes or somewhere like that. Actually, in your area, ordering on Amazon and having something delivered might be worth the price. Some low end surface mount fixtures would do a nice job. Converting the 8ft fixtures would have been a hassle. Get yourself something nice, Clark.
Again, not an expert, but on this topic - cheap-ass florescent lights - I am.
I spent a few hunnert bucks on them thru Sam's Club and thru Home Depot. If you do, just keep your receipts.. I would go hard wire and not plug in. Quality lighting is near priceless.
I have brand new junction boxes in the ceiling just waiting for new light fixtures.
4-foot seems small. Especially when this space had 8 foot fixtures.
