What did you do to your 2019 and up Ranger today?
Just did an oil change (Valvoline Restore & Protect 5W-30 FS), but here's something that might surprise you guys:
I always do a 5K OCI (Oil Change Interval). For this OCI it was a bit over, 5200 miles but 2500 of it was a trip from Texas to high in the Colorado Rockies. Lots of hills to climb and engine braking on long down-grades, and I'm talking 4-6 mile long downhill grades.
On virtually every oil change other than this one, the computer states the "Oil Life Remaining" is always at 59 or 60%.
On this OCI, it was 17%!
So somehow the ECU determined that the Colorado trip put extra wear on the oil and drastically changed the oil life value.
Thoughts on this?
CMOS
Thoughts on this?
CMOS
You think maybe you forgot to reset it? I know the Vagabond trip was a touch under 4k miles. A lot of that was through mountain passes and up and down. With some high speeds across OK and TX. After I got back mine still said it was around 60% when I changed it after the trip
You know, I think you may be right. The math works in your favor. I did change the oil the night before the Colorado trip, so in my haste, it seems that's what happened.
Thanks for the clarification!
CMOS
CMOS
I also did mine the day before the trip. Then I was running out to Virginia for Expo East. So I was worried because once on Cinnamon Pass. I got the reduce power over temp warning. Mainly because I was running in 2wd. No problems after switching to 4lo. So I changed it before I ran to Virginia. Only reason I thought of it is because I've forgot reset it several times through it's life.
Wait, what's with the "reduced power" mode? I don't understand why the truck went there?
CMOS
CMOS
WAG;
High temperature. Computer went to limp mode to reduce temp.
CMOS
We were climbing somewhere around a 15 to 20% grade shelf road above 12,000 ft. Being in hi gear with all the extra weight from the gear was causing a few of our trucks running in high gear to get up into some higher temperatures. The system pops up a warning and alerts you that it's at reduced power. Lesson learned. I will run 4-Lo when climbing steep grades. Regardless of difficulty of trail. Most sections through the mountains were just gravel with terrific and terrifying sites haha. So I was just running along in 2wd.
I was the other one who ran hot and got put into limp mode. Like Robert, I'll know to get into 4 LO sooner. I also learned that keeping the engine RPM helps a lot in keeping the engine temps down. I was doing a lot of manual shifting and locking the transmission into lower gears. I think part of the problem is the oil cooler and the transmission cooler both use the engine coolant to cool the oil in both systems. I may change that by installing independent cooling systems in the future. The engine oil cooler will probably be pretty simple in just replacing it with a sandwich adapter. The transmission may be a different story.
Over last couple of weeks I have installed an off-road camera system, dash mounting system, and half of the switch panel. I am thinking about moving the camera system display from the mirror to putting it on the new dash mounting system. The factory mirror mount is very integrated into the truck and obstructs the inside cameras view. I need to fabricate a mount for the fuse panel under the hood. There is not a lot of space to work with under the hood. Any thoughts?
Over last couple of weeks I have installed an off-road camera system, dash mounting system, and half of the switch panel. I am thinking about moving the camera system display from the mirror to putting it on the new dash mounting system. The factory mirror mount is very integrated into the truck and obstructs the inside cameras view. I need to fabricate a mount for the fuse panel under the hood. There is not a lot of space to work with under the hood. Any thoughts?View attachment 135954
That the Wolfbox?
Event Coverage
TRS Merch
