2.3L ('83-'97) No spark help!
Kayden Schauer
Forum Member
Greeley
CO - USA
Vehicle
Drive
2.3L
4in
235/75R17
Hey I have a 1990 ranger with the 2.3L Lima, I have no spark. For a little back story I’ve completely rebuilt the engine and added a turbo from an updated thunderbird system. I’ve replaced every sensor and module in the whole engine bay because when it was running the cluster had no coolant temp and a whole bunch of vain air codes and sensor issues and was burning quite a bit of oil. Now I have fuel pressure and I’m trying to not wash out brand new piston rings but I’ve ran through the whole spark system (plugs, wires, coil packs, dis module and all the wireing for it). I have constant 12v power to the packs but no signal out of either signal wire and it’s the same with the old dis module as well as the new one. I’m a bit stuck.
If you forgot to hook something up, the computer should be able to tell you. Do a code scan.
Do you have injector pulse but not spark? On that system I believe (haven't looked in a long time) the crank sensor goes straight to the DIS module that gives an rpm signal to the computer for injector pulse
The '89-94 crank sensors are kinda dumb and like to give out randomly but it's usually hot then they'll work when they cool down, at least that's what the one bad crank sensor I've had did.
Go over all your wiring connectors. Make sure the orange rubber o-rings are lubricated. I had a problem with dry rings would force the connector apart just enough. It looked like it was connected but pins weren't making contact.
See that’s what the problem I had originally when it was running before I rebuilt it but I removed those a while ago and still no dice
See I also thought that but the original crank sensor worked fine before but I still replaced it thinks it was the issue and I also replaced it again thinking it was a bad part and no difference all 3 times. I’m pretty sure it has injector pulse I get the smell of gas when I was first starting to crank it so after that I stoped because something wasn’t right.
Let me try that but all I get from the light codes are barley anything it’s usually just 11 that is system ok
