- Jul 1, 2025
- Fort Myers, FL
- 3.0 V6
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- Stock
- My credo
- Run er' till she dies, then rebuild her again
A little back story....
Bought the truck from a dude who didn't know the first thing about maintenance
Did all the usual inspections; brake fluid dirty as hell, oil needed to be changed, but the coolant looked pretty clean. Overall, good enough to get me home. Did the test drive, everything seemed good, right? Right? Welllllll, about an hour into my 2.5 hour drive back, I noticed the coolant temp was creeping towards the hotter side of things
Pulled over, let her cool down, de-pressurize, and popped the rad cap off again...only to find brown sludge dripping off the bottom of the cap
Everyone knows what that is, I'm sure...so, limped her home, tore the heads off and replaced the gaskets. As I was digging into it, the further I went through the cooling system, the worse and worse it looked....until I got to the water pump. When I say this thing looked like it had see war, that's probably an understatement. What fins remained on the impeller were folded right over against the wheel, and the rest of the fins...gone. Idk where to, my guess is straight into the block. Didn't have the necessary tools or money to dig deeper, so I slapped pretty much a whole new cooling system on it and called it good. New pump, thermostat, heater core, hoses, radiator and cap. However, when I go and start this thing up, I have to put my fill funnel on the radiator and let it get up to temp before I drive anywhere. The reason being, as it gets up to temp, pressure builds until it back fills my funnel almost to full, then sucks it all back down. She's now good to drive at that point.
My question is, has anyone else experienced something like this before? Could pieces of the old water pump be causing this issue? And how impossible would it be to fish those little buggers out of the block if it were the culprit?
Thoughts?
Thoughts?
