Wanted FX4 Level II Shifters (4x4 and Transmission)
PlumCrazy
2014 Truck of The Year
Millersport, OH
Like the title says, looking for the chrome FX4 shifter for an M5OD
Try car-part … I stumbled on a set (trans and case) on that site and got them shipped for little to nothing. Also got the case linkage.
bump. Also looking for the t-case shifter and boots
You’d have an easier time finding a hen with teeth.
Already snagged a t-case shifter, bezel, and boot. I figure Ill keep my WTB up a little longer.
Good for you!! But it’s not the t-case shifter that everyone wants, it’s the M5OD one that’s so rare.
I machined this adapter from a piece of steel for my build, it uses the original cam bolt and nut. It should fit either an R1 or R2 trans.
I used 3/4" all thread that I bent an angle on for the arm. Something similar might work, then you could build the arm in whatever shape you wanted. Just a thought.
I like this. Might have to steal the idea!
I'd likely attempt to make it from a stock lever. Being the cheap bastard that I am. I'm currently using one made from conduit. It works.
I'm pretty cheap myself, made it from junk I had laying around. Here's a couple more pics for ideas.
Thanks. I guess it really only needs to be three holes drilled into a block of steel... Just have to get the bottom 2 just right so it'll lock on tightly.
That's the gist of it. I copied the stock one but omitted the key. It locks solid but will fit either trans.
