- Aug 6, 2007
- Shangri-La
- State - Country
- GA - USA
- Drive
- 2WD
- My credo
- Alas poor Toonces; I knew him well.
From the ignition control module connector it comes out one black wire then goes into that yellow and black tube which we're believing is shrink tubing.
Then comes out it appears to be two separate bare wires.
But where do / does the OTHER end(s) of that bare wire go?
That spot that @alwaysFlOoReD pointed out does looks suspect, too.
Here is the spot on the bare wire that caught my attention:
But it's really hard to tell from still pics (even though your pics are good), versus having things in your hand and being able to move them around and look from differing angles. Your later pic, that spot looks OK, so the spot I commented on may actually be on the pink wire, not the bare wire.
This:
Looks like a probe, such as a test light, was stuck in the wire sometime past. If so, these open holes in the plastic insulation will let moisture start rotting the copper strands on the inside. You may want to look carefully at that spot. That white spot on the opposite side of the wire from my yellow arrow, sure looks like corrosion, and a hole where the probe came out of the wire.
I think that your current problem is just janky wiring.
You've got this; just be thorough, use common sense along with your EVTM, and repair any questionable spots in a workmanship-like manner.
