M5R1 Extension housing question
Hoofaarted
Alta loma
3” suspension 3” body
33/12.5r15
does anyone have the part number for the splined seal that goes around the tail shaft of the trans and also the plastic piece that seems to help oil the bearing( all inside the extension housing) also am I missing any other seals, I got this trans with the extension housing detached.
When everyone gets back from the holidays, i am pretty sure a few people could help you with that stuff. I cant though
sweet, fingers crossed. The ranger has been sitting for a year so I’m excited to get it back together.
This might get some better responses in the tran section so I’ll move it over there…
I wouldn't stress about the rubber splined thing, it just sits at the front of the T case input for whatever reason... the plastic thing by the lower bearing I'm not sure of but if you call Transmission Exchange Co out of Portland Oregon 503 248 0768 they will likely have the parts, I've bought several M5OD parts off of them and they had them in stock, same with the parts I needed for my ZF5...
None of my 4x4 transmissions had them to begin with. I have only seen them on the 2wds (I assumed it so you didn't bottom out the drive shaft slip yoke during assembly)
