Brain75
- Aug 8, 2024
- ~Sterling
- State - Country
- CO - USA
- Vehicle
- Ford Ranger
- 2.9 V6
- Tire Size
- 215/70R14
Edit: All questions answered. Post #10 has all the meat and 'taters explanations.
www.therangerstation.com
and Post #34 has the final wrap up, thoughts, and PSA.
Recently I got a salvaged dealer add on cruise control kit (dealer add on, not factory) from Shran that he saved of a '94 mazda B4000 headed to the crusher.
Everything looks good and I managed to figure out partial part number and get a schematic just from googling (there was no label on the brain box, but later I found out the only label would have been "Ford" - see pic in ebay listing below)...
Part number is going to be something-9A818 where "something" is unique over every single model of vehicle, but the Ford shop manual just refers to them all as 9A818 ...
an example would be E8TZ-9A818-A for "88-91 trucks" listing does not specify full size or ranger/mazda...
Anyhow, pictured in the ebay kit is a speed sensor, and in this shop manual drawing it's part number 9E731
(pic courtesy NumberDummy over on FTE)
The one single thing that stops me from running right out and grabbing one is the SAE connector that plugs into already has a lead on it (coming from the mazda donor).... and all this is doing is supplying a series of pulses. I think the "brain box" is too smart to even care how frequent the pulses are, it just tries to maintain the same rate of pulse is all (I figure that since Ford seems to have one generic universal no matter 4 cyl, 6cyl, no DIP switches, no programming, nothing - they are "smart" dumb boxes) I have to ponder this.... so here's the question for @Shran (dig into that old memory) and of course anyone else who can answer. Couldn't this just accept VSS+ coming out of the EEC-IV computer and skip the extra part? (Is that how it was setup on the Mazda donor?)
here's my "parts pile" - looks like Shran was very good not to pull it all apart and left everything as it lay - which helps a lot for figuring things out.
Pin 1 coming out of the brain box is the red, and pretty obviously power in (inline fusible link sealed up)
Pin 2 is the green and after the butt connector splice is the same gauge and off shade of green as all the brake switch hardware.
The clutch switch is a simple dead man vacuum - once the clutch is depressed ("letting go" of the deadman vacuum switch) it dumps all the vacuum pressure out of that line. Everything makes sense and it looks like a simple "go buy a bunch of vacuum hose and maybe a reservoir"
I ask because well I am cheap I don't want to fry it by just "playing around with it till I get it to work", if anyone knows for sure I much rather hear from them then blindly play around till I screw things up worse.
Dealer added cruise control - works!
Edit: All questions answered. Post #10 has all the meat and 'taters explanations. https://www.therangerstation.com/forums/index.php?threads/dealer-added-cruise-control.211057/post-2062731 and Post #34 has the final wrap up, thoughts, and PSA. --------------------------------- Recently I got a...
