- Nov 17, 2024
- Salt Lake City, Utah
- 2.3 (4 Cylinder)
Hello, new here but have been lurking for a while. I came to own a 1992 2.3 Ranger with Manual transmission a few years back. Motor was crap from the previous owner, it still ran and drive alright, about 8-9 months ago my father and I rebuilt the whole motor and she has been running like a top, until two days ago.
I broke down at the parts store and spent a few hours trying to diagnose the issue. The motor cranks over, good spark to all the cylinders. However, I don't hear the fuel pump prime or turn on. I had to have it towed because or a lack of daylight and tools.
I checked every fuse 3 times, all good. I had purchased a fuel pump relay at the store and that didn't work either. I checked the voltages being sent to the fuel pump relay, with the key off I get a single 12v constant, with the key on I had 12v, around 6v assuming this is from the inertial switch, and then another connection was 3v. After further reading about what the voltages should be, I suspected the EEC relay was the culprit. I used the new fuel pump relay for the EEC relay after reading they're the same. Sure enough pump primed and it started right up, I let it idle to charge the battery while I buttoned up the under hood fuse box. The check engine light was on but engine seemed to be running perfect and even charged the battery. I shut it off and turned it on again, no check engine light and still running great. However, when I pressed the brake to release the hand brake and drive it, the engine died and wouldn't start again.
Now I am back at square one, engine cranks no problem, good spark, but the pump won't prime and the engine won't start. Voltages are still good at the fuel pump relay. Now for some reason the dome and cargo light wont turn off as well. I found the door switches for the light and when I press the passenger switch closed the light slightly dims .I am at a loss how to solve this, currently thinking of getting a new inertial switch and another new relay, so the EEC and fuel pump relay are both new, and I know they're not the issue. I plan to clean the 2 grounds next to the ECM as well. Any help would be greatly appreciated, thanks.
