1992 ford ranger 2.3l
I’ve replaced:
Fuel pump
Egr valve
Fuel filter
Spark plugs
Coil packs
Wires
Maf sensor
Ignition control module
Tps sensor
New gas
Air filter
Cleaned throttle body
Fuel pressure regulator
Issue I’m having is under load the truck will hesitate and backfire. This typically happens when I push the thrttole to the floor it will jerk hesitate and backfire but idles fine and starts every time it will do it occasionally at idle when I floor it (just to make it happen) but sometimes won’t do it. I noticed the truck will run at what feels like 100% power on a good warm start but parked it for 10 to 15 minutes go back out and drive and it does fine for about 5 to 10 minutes but then will start acting up.
I’ve replaced:
Fuel pump
Egr valve
Fuel filter
Spark plugs
Coil packs
Wires
Maf sensor
Tps sensor
New gas
Air filter
