- Aug 11, 2007
- Age
- 70
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
I went this morning and pulled the kick panel and hit the switch to see if it reset and it didn't so I'm assuming it's good, unless it can go bad without it resetting.
I did drive to Napa this morning and bought two relays one for the fuel pump and the other for the full throttle cut off ac wac relay. I replaced them in the parking lot and as I drove home I noticed a very notable improvement in acceleration response. Also, the starting of my truck went from 5 seconds give or take to less than 1 to 2 seconds.
The inertia switch can be on/off wonky...works fine till you hit a bump and then cuts the fuel pump either completely requiring a reset or partially with no reset needed.
I would go with the route you are following but keep the inertia switch in mind...if the MAF sensor does not fix it 100% you can try bypassing the Inertia Switch later...
On my Tempo the guy that actually discovered it was the inertia switch almost overlooked it...but he decided to pull it out of the trunk and have a closer look...and the back side of it was a melted mess...he said it was surprising it even worked at all...but when we replaced it all my symptoms vanished...never had a problem with it after that...
