4.0l ohv camshaft sychro stuck in block
So. Illinois
I Have 1998 ranger with the 4.0l and I'm trying to change out a bad camshaft synchronizer. I can not get the synchronizer to move at all, the casting won't rotate and I can't pull it out. Does anyone have a suggestion? I've pulled the upper intake to access it but it is still so far down there. There is no way to grab it.
Here is some info.
The screws that hold the cap on stripped out before the sychro came loose. Slide hammer failed.
  • 4.0l ohv camshaft sychro stuck in block
Did you ever manage to get it out? Struggling with the same issue on mine
I tried to pull that damn thing out about a dozen different ways for a month. I made special tools to grab it and twist it and lever it, but where it was located, you couldn’t get anything on it. I checked with everybody I knew, and an old mechanic friend gave me this:
Poor brake fluid all over it for a couple days. I had to make a funky angled funnel out of some paper rolled up because even that was hard to do!!
The reason it’s frozen in the hole is the greasy carbon crud is rock solid around the top and the O-ring. The brake fluid will eat that up in a couple days. Then I just tapped it sideways a couple times with a 5/8 inch wrench, actually very gently, and it started to move. Once it started to move, I could work it back-and-forth and eventually it came out. But it didn’t come right out or easily, I had to wiggle it forever, and eventually I worked it out.
CAUTION: if I recall, it’s a tiny 5.5 mm socket for the little screws that hold the electronic cap on. 10mm for the hold down screw and washer. The screws are made so they stay in the cap, but that bolt and that socket can fall right down in the hole when that synchro comes out. Guess how I know that. I have one of those five dollar telescoping magnets from Harbor Freight, and thank God, I was able to stick that down the hole and pick the socket out. It’s my own fault and my own stupidity, because 99% of the time when I’m working with something like that, I use electrical tape or masking tape and actually tape the joints of the ratchet and the extensions in the socket so they won’t slip off. Again, if I recall, right, I had three wobbles extensions on a quarter inch ratchet and a universal just above the socket, and you had to slide that in perfectly to get it to get to those screws.
Hope it helps
EDIT AFTERTHOUGHT: you also want to buy the alignment tool kit. It consists of five or six different colored caps that fit where the electronic sensor is on top.
Pick the right one, and it goes where the electric cap goes on, but before you stick it in the hole. BTW, I’d bathe that thing in WD-40, because it was almost as hard to get in as it was to come out. Angle/twist it when you start because when those spiral teeth engage, it’s going to twist a little bit. You want the alignment tool (which mimics the electronic cap) to be pointing somewhere backwards. You don’t have to get it in any precise spot, as long as you can get the plug into it. When you take that plastic cap off, and you put the 10 mm and washer back in, it will be aligned properly when you plug it in.
Remember to disconnect your battery for at least 10 minutes. Turn your air-conditioning on high before you put the lead back on, and let it run for two or three minutes after you start it.
If you have to pump the gas to keep it from stalling, let it level it out, but then do the exact same thing a second time. It should start up and level out on its own. If you have to tap the gas, that throws the learning off, so maybe a third time.
And one last thought, I replaced most of the engine control sensors before I zeroed in on that synchro. When I got that in, I still had a check engine light show up. It turned out that I had a faulty brand new coil six pack that I had to replace a second time.
Hope it helps.
If you need more detail, PM, me and I’ll give you my phone number and we can chat
Hope it helps
Hope it helps.
You may very well be my hero; I tried everything I could think of (PB Blaster, prying tools, tapping with a hammer, heat, yanking with vice grips). I have a large container of brake fluid that still has some left after a recent brake line job, so I'll start pouring and see if your trick works. Fingers crossed. Did you lay anything out to prevent the brake fluid from dripping down into places you didn't want it, or were you not worried about it?
The replacement synchronizer I bought did at least come with an alignment tool, and I already had cylinder one at TDC on the compression stroke. I was completely ready to finish the job when I found that the damn thing was stuck in the block. I need to get rid of my CEL so I can get it registered (I bought it a few months ago), so I'm getting pretty desperate. I am at least highly certain it's the cause of my CEL because it's what the seller said he thought needed changed, and when I took the sensor off the top of the synchro, I could see that the metal tab that's supposed to send the signal to the sensor was broken. Seller probably just realized it was seized in the block and didn't want to deal with trying to get it out himself lol
I'll follow up and let you know if your advice works
I wasn’t worried about the brake fluid flowing down. While my truck is a custom, it’s not one of the super polished show trucks. I wasn’t worried if the brake fluid ate the paint off something else below.
Now, having said that, now that you mention it, it’s probably not a bad idea to put something down there to absorb the excess so it doesn’t eat up any gaskets or something like that. Also, when you finally get it out and put the new one in, shoot some degreaser down there, hose that off, and then shoot some soapy water down there, and hose that off. That should take care of enough of the brake fluid residue that it won’t hurt anything.
And it wasn’t my idea, I was just as stuck as you are, but I’m a good copycat once somebody gave me the tip.
That's not a bad idea; I've just been using brake cleaner to clean up the surrounding areas after pouring the fluid so far. Although mine isn't exactly a show truck either lmao, so I'm not terribly concerned with appearance. Just don't want to mess up anything functional
You say you spent a couple days pouring brake fluid all over it. Did you regularly pour throughout the day (like 2 to 3 times), or just once in the morning or something? And did you use any tools to pull it out or just your hand? Since it's in such a PITA spot, I've been tugging on it with vice grips so far
I just poured some on yesterday, but I am a horribly impatient person when it comes to this kind of stuff and now that I'm well overdue to register this truck, I'm getting antsy about it lol
Once I got the suggestion, I made an angled funnel out of some cardboard, so it would pour right over the top of that thing. I probably did it twice a day, maybe three times, for a couple days. i’ve got extra vehicles to drive.
You know you kind of have to stand upside down and backwards to get your hand back there. I kept trying to wiggle it, and I would tap it fairly gently with something like a 5/8 inch wrench. I wasn’t trying to knock it loose, as much as shock it to pop the hold of the built-up crud. I think it was on the third day that it moved the tiniest little bit after I tapped it. Once you feel it move, then you know, you can eventually wiggle work it free.
I wrote it all up, I think in the thread what did you do with your Ranger today, but what I just told you is the meat of it. I went to college for chemical engineering, and I ran a lot of operations, and this is a classic example of let the chemical do the work. You don’t need gallons, but I’m sure it doesn’t hurt to dribble a little bit more two or three times a day. But once you do that, you just have to let it eat away at the caked and baked on crud, and then it will start to free up. I don’t know any way to rush it.
And yeah, patience isn’t my long suit either…
Well unfortunately I haven't found success yet; it's been soaking for about a week (thanks to some bad weather keeping me from working on it), and it doesn't seem to be loosening. Although my main problem is that the edge of the synchronizer actually chipped off when I tried tapping it loose early on, so I don't really have a good way to try and hit it. Damn thing really is in the worst possible spot. I'll just have to keep trying and hope enough tugging will finally work I guess lol
More brake fluid. Maybe rig some kind of a brush, like a paintbrush with most of the bristles cut off, so it’s almost like a baby scrub brush, and wiggle it in there and under the head to try and work, the brake fluid in and clean out whatever crud. Maybe go and see what else you might be able to pour on it that will eat the crud up without eating the engine up.
