- Feb 28, 2001
- Dayton Oregon
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
Being a '92 you can fit 31" tires stock, wouldn't hurt to put some washers under the front coil seats (get some 1 1/4" washers and put them in, not a horrible job, can fit up to like 1" of washers under there) for some more room then just go have fun. If on a budget that's what I would do, you'll want to get an alignment or at least the balljoint sleeves and look into doing one on your own as any lift will need correcting...
As far as needing bead locks or anything silly, no, as long as you aren't airing down past what's necessary just carry a portable compressor (the harbor freight ~$60 on sale high pressure one is good, next step down is ok too just slower), for reference in sand I run 10psi in front and 8psi in rear and a little lower in deep powder snow but you have to be a bit more careful...
In case it wasn't obvious earlier my '90 has a Dana 35 up front, completely stock other than full circlips around the U joints, little clearance ground into the shafts for more clearance before binding, opened window in the passenger side beam for the axle shaft and of course 5.13:1 gears... now I have increased the length of the radius arms to take advantage of my lift and such... in the rear it's a Explorer 8.8" with traction bar and Yukon Grizzly locker but otherwise stock... I got the lift kit used on craigslist for $500 and had to make my own leaf spring packs and use 3" blocks which made the traction bar necessary...
A stockish rig on 31" tires is nearly as fun as a moderately built rig on 35" tires... and annoyingly nearly as capable unless you're getting into hairy situations in rocks or mud holes...
