‘84 ford ranger needs the bed off to replace fuel sending unit but I have no idea how much it weighs like if it’s a 2 man or a 4 man job looked all over online wouldn’t give me an answer
Two people minimum, as long as they can actually lift something. Last time I had to move a bed it was three of us, but I was the only one who could actually lift it, the two on the other side together couldn’t. That was rough. Four people make it super easy. Two average adults should be plenty capable. Engine hoist or machine of some type would make it easy.2 man job, one on each wheel arch. Take the tailgate off for an added weight drop.
I think the 6 foot beds are around 300ish lbs, I have removed mine with one other helper a couple of times. 6 bolts, three screws on the filler neck and unhook the taillights right in front of the rear bumper and lift it off.
I have also seen it lifted off with a harbor freight engine heist and a chain...
AJ
I have done the bed solo before by jacking it up, end at a time, sliding 2x4's under it and setting their ends on stacked cinder blocks. Rolled the truck out from under, and then back in for the reinstallation.
Gotta be creative when you're a hermit . . .
I don't have to do anything janky for that. Just making an apearance in the yard where they can see me can be enough. If it weren't for the vehicles occasionally moving and the lights being on, I think they'd forget that someone lives here. If their cats don't stop fighting in my yard, I'll given them a reminder in the middle of the night.don't be afraid to scare the neighbors![]()
And will you other guys need to eat more spinach and spend a little more time at the gym…
Getting the mud flaps and fenders over the rear bumper is the hardest part.
Alone, you can move it enough to get at the sender.
If you want it off completely, two people can do it. 3 or 4 people, it takes less then a minute.
My wife helped me put the bed back on my truck once, she may have even been pregnant.
OK; and how much spinach would be needed, to change a tire without a jack?
I was approaching things from the position of not scratching the paint, but your method works as well.
That said, I'm definitely in this category. It would probably do wonders for my sleep, energy, and blood sugar problems. My energy problem is a direct result of lack of sleep, my lack of sleep is a direct result of not being tired enough. If I'd spend some time in the gym, or working exercising in general, it would probably fix the lack of tiredness. The calories burned would help with the blood sugar. The fiber content of the spinach would helps with blood sugar control as well.
