Had the AC compressor replaced. Before hand the idle would go up maybe 200 RPM when AC was engaged, now no rpm increase. In my experience when ac activated the idle would go up to compensate for load. Am I wrong? TIA.The computer controls the idle speed. You can clean the throttle body and the idle air control valve, and the computer may control it better, but it has the last say in idle speed.
Hard to say how they have it programmed. If the compressor engages and the rpms stay the same, it is definitely compensating for the extra load. Is it supposed to increase the rpms above normal idle rpms? Not sure.Had the AC compressor replaced. Before hand the idle would go up maybe 200 RPM when AC was engaged, now no rpm increase. In my experience when ac activated the idle would go up to compensate for load. Am I wrong? TIA.
