Mike92STX
- Jan 14, 2012
- Zion,Illinois
- 4.0 V6
- Tire Size
- 245-75-16
I have a 2004 4.0 Ranger FX4, I was looking at my air filter and noticed some oil in the tube between the filter and the throttle body. I did a little research and found that the oil in that tube can be caused by the PCV valve being plugged. When I checked the PCV it wasn't even in the hole on the back of the valve cover? What a PITA to change the PCV, I had done the change before, but I forgot hoe awkward it was. My question is the PCV has high spot so it looked like it should twist in and be snug on the back of the valve cover. Mine just slid in the hole what is it missing, a matching notch or was there an insert in the hole to hold the PCV in??
