- May 15, 2020
- Age
- 70
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- 4.0 V6
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
...and that would be the reason I said the spell to summon the resident Rust-Oleum expert. FWIW the Farm & Implement come in non-spray version. I'd be most likely be painting with that, and using the spray can for later touch-ups.
Also I completely agree with @don1331's post. The damage in the video you posted is aft of the axle. All of that is in the aft frame section.
You do seem to be adverse to doing this work yourself. If this shop you're talking to won't do rear frame section only, shop around for another that will. You'd be better off doing it yourself if you can.
@pentode this guy is stressed because he doesn't know enough himself, and he's getting too many different responses from too many sources. I'm guilty of being one of those myself. I think I was the one that initially brought up the possibility of frame damage on his truck, and it has kind of spiraled from there. Some of those sources seem better than others, and from his position it would be kind of hard to determine which are which. Also, if I were going to do fluid film, it wouldn;t be done until after the repairs are complete, and I think I'd probably still do frame paint before the frame went in (assuming we're still on full frame replacement).
Let me throw out another thought. My son used to say I couldn’t use a vending machine when he was a teenager. The third time he said it, I bit. He said “dad you’re so cheap when you hold onto that nickel you bend it, and it won’t fall down the slot.” Of course, he said this while he was driving my old Mercedes in college that I paid for.
I’m cheap, but I’m not stupid. It’s all about value, slopping on the thin rust oleum and sloping it in the joints flat just works. I don’t know who said it could ship, or that you could touch it up with spray. When I’ve done the two or three layers as described, it really doesn’t chip, if it chips it’s only on the surface and not down to where the rust starts, and if you slop a little more rust oleum on it, it bonds and lasts.
Lesson over. My 2cents, I hope it helps.
