- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
Mine does.I wasn't going to remove reservoir that's already there just put a check valve just B4 the inlet to the check valve that failed. Your saying that ll make it run like shit for a bit after startup?
So bad i thought i had coolant sensor issues.
Like it is hard to get started, then for 30 seconds or a min after it does start if you do anything but very lightly slide into the go pedal it just stalls.
