- Apr 30, 2024
- Moncton NB
- 3.0L
I ordered a couple quarts of gear oil for my old datsun transmission (brass synchros) from rock auto- their website pic claims to be GL-4 and GL-5 compatible. However, what I received only says GL-5, otherwise it's the same label.
I called Lucas and got the most confusing answer possible. They said "We've changed the formulation and the label. It used to say GL-4 but it wasn't yellow metal safe. Now it's GL-5 only but our technicians say it's definitely yellow metal safe now. However, I can't advise you try it in your transmission"
Super fishy. Why would you _remove_ the GL-4 from the label if you specifically went out of your way to make it yellow metal safe? Even Lucas doesn't seem to understand the difference. I'm now leaning towards not even trying this stuff but I'm curious if anyone has any good, solid insider info about this situation.
