- May 30, 2024
- Indianapolis, IN
- 2.3 (4 Cylinder)
You're obviously a DIY guy, I'm sure that's why @RobbieD and I chimed in. Please any HVAC guys on here don't take offense, but A/C is mostly just physics and plumbing. Oof I know that might be controversial. I'm pretty sure a vacuum pump on Amazon is like $100US. Gauges are probably $50.
Assuming your system is clean and no shrapnel in it, you just need enough oil to lubricate the compressor, pull a vacuum, make sure there are no leaks, then put the right amount of gas in it. It's just basic science, not rocket science.
Yea I was just looking at that. Wow. Those pumps used to be megga-bucks. Now they are $100~. One thing I insist on is a good set of gauges though. I've had some infuriating experiences with those chinese amazon test kits. The gauges ALWAYS fall apart after you use them a couple of times and who knows if they are even remotely accurate. If someone has suggestions that aren't Mac or Snap-On prices, I'd love to hear it.
I'm under-selling myself a bit on the AC understanding. I know how it works, it's a rather simple concept. I just lack detailed knowledge, all stuff I can probably learn pretty quickly as there isn't a lot to it really. And yea, this system is clean, it's all brand new except the evap core and that was because the new one I bought was a hunk of junk and I didn't trust it. The old system had leaked down to almost zero (it still had a little pressure in it, just not a lot), but everything was clean and the old orifice tube still looked brand new, wasn't a speck of anything on the screens. I've kept everything sealed from atmosphere except for the short time installing it, so it should be in decent shape overall with minimal moisture. One thing I'm confused about is oil. The compressor supposedly came pre-oiled, but 1) I don't know if I can trust that and 2) how much total the system is supposed to have in it. I assume I can find that in the Ford shop manual if I look hard enough though. I don't have a $5K dollar recovery unit to pull it out and measure what is in there already.
