lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
Definitely is worth checking, I’ve actually come across the big 4-gauge frame ground from the battery look perfect but be corroded to junk in the insulation. I only thought to check when I realized the wire sounded very crunchy when I moved it and that was enough to get curious enough to skin some insulation off and find the culprit. I replace all of the heavy gauge wires with welding cable and use dielectric grease or No-Alox (electricians use it for connecting aluminum wire to keep corrosion at bay, I’ve bought it from Home Depot so it’s readily available). Just remember the No-Alox is kinda like anti-seize and is electrically conductive. Dielectric grease is a silicone grease that is not so electrically conductive. So use appropriately.^^^ yes to poor connection.
The heavy cables to and from battery and starter and ground all need to be checked. A loose connection, corroded wires under the insulation, or broken connection that slightly touches intermittently in the insulation or cable end are all responsible for a click sound from the fender solenoid (relay). Sometimes a series of rapid click sounds if low battery.
