- May 15, 2020
- Age
- 71
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- Vehicle
- Ford Ranger
- 4.0 V6
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
It rained here Friday night a little bit, soaking wet this morning, and it was over 80% humidity all day, Saturday, and it got up to 92°
I used the last of my free bed frame stock to try and make a kind of rack to hold the air tank behind the drivers door next to the toolbox. I don’t know if it went like crap because I’m incompetent, but I suspect it had something to do with the 85% humidity and 92°. Even with a fan blowing right on me, I was soaking wet and frustrated and I just couldn’t get it right.
I’m bolting it to the side of the truck frame, one bracket on either side of the spring mount. The driver side spring mount is also where the emergency brake cable splits into two to feed both sides of the truck. And that’s the gathering area for the 20 or 25 wires for all the toys I’ve added that work through the toolbox. Since I can’t get a nut on the backside of the frame because of the gas tank, I decided to drill and tap holes right in the truck frame. Thank God, I took a small dowel and checked behind the frame to see if anything was back there before I drilled the holes. Nothing important, just brake lines and fuel lines. After four or five hours, I was thinking it just wasn’t meant to happen.
Not to be defeated, after a break and cooling down, I took some scrap unistrut angle I had, and basically fabricated the pieces with the unistrut.
I’m tempted to leave it, but it’s just too flimsy, not strong enough. I’ll get some more free bedframe parts or angle and weld it up now that I have a template. Now that it’s done, it’s a little erector set, and it comes in and out pretty easy.
I also finally trimmed the diamond plate on the main deck of the step trailer, so it runs fairly straight down the sides now.
I have to check the list, but I think that leaves me with just paint and touchup and cosmetic stuff. I’m hoping to have it done by next Sunday and take it to Kennesaw for caffeine and octane. I’ll go either way, it would just be nice if it was sort of done.
