Driver's side drum getting hot after brake job
Junk Collector
Truck of Month
Rapid City
SD - USA
Weird problem - I did a brake job on my '94 and it included new shoes, drums, hardware. The driver's side drum is getting pretty hot and the passenger side one is not - I drove it a few miles and checked it with an IR temp gun - it gets up to about 170 degrees and the passenger side one is at about 90 degrees. It got hot enough to turn the OD of the new drum sort of a straw color.
I tried a different wheel cylinder and star wheel adjuster. Neither made a difference. The shoes are not super tight, I can slip the drum off fairly easily without loosening them.
Kind of at a loss here. Do I have a bad drum maybe? The old brakes were not hanging up at all, they worked fine, I swapped axles to get a different gear ratio and figured I'd do a brake job on it while I had it apart.
Bad bearing at the end of the axle?
Confirm both shoes are firmly seated on the anchor pin.
If not the park brake cable is too tight.
Man I don't THINK so... there is a very tiny amount of lateral play in the shaft but I compared it to a couple other axles in the pile and it's not really any different than those.
I put a dial indicator on the shaft and let the truck run in gear with no drum - just to rule out a bent shaft - there was maybe like 0.005" of runout. Not much.
I guess I could replace the shaft & bearing, I have plenty of spares but let's leave that for a last resort.
Shoes are seated as far as I remember...I've had it completely apart several times and didn't notice anything weird. I will double check.
Does the parking brake pull on the driver's side first? I didn't adjust it at all, nor have I engaged it... ever... figured since the drum slipped on & off fairly easily I wouldn't need to?
I'm gonna run the drum down to the parts store and see if they can put it on their lathe and rule out a bad drum. This was a $10 Rock Auto closeout item so it's possible it's out of spec.
If that checks out I may swap drums from side to side and see if the problem follows the part.
If you can wiggle the park brake strut... the cable isn't too tight. I also think the park brake pulls the passenger side first.
Perhaps a long shot... but the backing plate isn't grooved bad enough to not let the shoe return properly?
@Uncle Gump your expertise was very helpful... thank you.
I think I have it fixed - I changed 3 things:
#1, had the drum turned. The guy who turned it wasn't there when I picked it up but the other guy said they wouldn't have turned a new drum if there wasn't something wrong with it... so I'm guessing it was out of spec somehow.
#2, I did find a shallow groove in the backing plate where the shoe contacts it but only on one of the little pads. I smoothed that out with a flap wheel.
#3, I greased all of those wear pads and the anchor pin. Admittedly I have NEVER done this... never. Didn't feel it was necessary as I've never found any grease there when disassembling old brakes... but it can't hurt.
Took it out for a drive and that drum stayed much cooler. Figured I would take the other side apart & re-check/grease that and found a damn seal starting to leak!!! So now it's torn apart for new bearings & seals, which I should have done to begin with.
Normal looking:
This one had a visible groove worn in it.
Ya know... I was taught that way in school. It was reinforced by my mentor starting out as a mechanic. His reasoning was to prevent a squeak when braking... which would certainly be a comeback. But it's really two-fold.
If it's squeaking... metal to metal... and it's wearing that dreaded groove.
Another note...
The bigger the squeak... the further out you are on the brake adjustment. If it just a tiny squeak... brakes are probably adjusted fine... but dry and wearing grooves in your backing plates.
Your groove doesn't look that bad... but it might have been enough.
The other side had a groove that was worse but it wasn't dragging so I guess I'm at a loss as to what exactly caused it but am not complaining either.
I did notice that after greasing everything, the assembled shoes return to center by themselves if I push it off center. Prior to that they would not have returned to center at all without pushing them there... so I guess that by itself is a good thing. I will just consider myself educated & do better brake jobs from now on.
