- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
Im not super up on the feedback 2150's.Any ideas why issue might persist? Tfi related? Idles really good just still has a hesitation at WOT. Does run alot smoother and responsive since the work i did do.
Generally on the older mechanical 2150's a hesitation right off idle would be the acclerator pump.
Bogging at full throttle would be most likely the bypass/power/WOT (whatever you wanna call it) valve, or incorrect float setting. It could also be a vacuum leak, or choke issue (as in its not opening)
