My New House & Workshop
I put a “utility sink” in the laundry room in my old house. I say “utility sink” because it wasn’t one of those cheap plastic slop sinks. I went to a restaurant supply store and bought a nice stainless steel industrial kitchen sink for a few bucks more than a new plastic slop sink.
What are the red and blue feed lines higher up on the wall for, what will they feed?
That's where the tankless hotwater heater is going. I was originally going to put in in the vanity on the other side of the wall, but I didn't have the required clearance around it, so I put it inthr bathroom and mounted up on the wall away from small children.
I've now been in my house for 10 years as of the 7th and have gotten kudos from people from the neighborhood, it does the heart good...
Some of the big intimidating projects get less bad over time, a lot of stuff doesn't phase me much anymore...
I added a utility sink to my laundry room as there was a drain and two water outlets next to the washer and dryer, I bought one from the habitat for humanity re-store and plumbed it all up nice and good, tried it out for the first time and it just drained into the wall... turns out someone replumbed the drain for the washer and just left the sink drain just cut off in the wall for some reason... I hate people... :)
What are you going to do when the wall fills up?
Just what are you going to be doing with small children in there?
No, scratch that, I don’t wanna know
Conveniently it leaks to the inside instead of filling up... It's been on the list of things for like 5 years, not a whole lot of room to tee it in... the most likely case is to move the sink to the shop once I get water to it but I gotta trench to the septic tank when I do that...
Work continues:
I re-used the sink that was in there and replaced the faucet and drain. There wasn't room for a vanity so I didn't see any point in wasting money on a new sink.
Today is probably the first time this sink has had water flowing through it in a decade or more. Still a lot of work to do.
I wish whoever originally built this bathroom would have put the sink and toilet on the same wall. This is a really poor layout. I would have to put up a 2x4 stud wall up behind the toilet to run the sink drain, and there isn't enough room between the toilet and cinderblocks for a 2x4 wall.
Probably could have had the drain pipe simply go left into the wall or had a cabinet under the sink?
Ya, probably. I'm probably going to kick myself for not moving it to the other wall, but as much aggravation as this project has caused me, I'm not starting over now. It's still better than having to walk out and go to the house.
. . . and it's even better than peeing in the alley, I suppose.
Your work really looks good, Jim. You should have been a plumber; you'd be rich and retired by now.
Afterthought, but wasn’t the toilet wall the original back wall of that building? And then there was another addition?
I’ll bet you the reason the sink is on the wing wall is so they could run the feed plumbing on the inside of the building and not one of the outside walls.
Not important, just a thought.
I have spent the last 6-8 weeks working on the outside of my shop. It's finally painted, and I'm really tired of working on it.
I had to stop working on it for about 5-days. I was working in the eave and stepped off the ladder onto a board with a rusty nail sticking up. The nail went through my shoe and into my foot. Hurt like hell. Went inside, washed my foot, and then put peroxide on it, and then lost my balance, grabbed my towel holder, and almost pulled one end completely out of the wall. So, after I was able to actually stand on my foot again (it was swelled and sore for several days), the first thing I did was fix the towel holder. I'm really thankful that I didn't end up with an infection or tetanus.
Anyway, I was trying to get the building painted before the temps got over 90 degrees. I finished painting it last week with temps in the high 80's. This week we're in a 100-degree heat wave, so I just barely made it. Today I finished trimming around the man door on the side. I also repainted that door with the paint sprayer.
I had to replace a few areas of facia and eave that were rotted.
The previous owner had allowed vines to grow up the backside of the building and they actually found gaps in the eave and made it to the attic. I removed all the old dead vines, and then sanded the areas where they attached themselves to the wood. When I was done, I went around and caulked the eave and facia so there's no more gaps and future homes to unwanted pests.
I primed the bare wood before painting it black.
I replaced the old eave vents with new ones. The new ones are twice as wide, but I could only find them in white. You can't paint them because the have a screen in them to keep bugs out, and they'll get plugged up from the paint.
I pressure washed the building before fixing cracks and places that were missing mortar.
I had a gap on the backside of the building where the addition had been put on.
and filled it in with mortar.
I got some paint color matched to match the house and painted the top 3 courses of block with a brush, and from there down with a sprayer. I didn't want overspray on my eves freshly painted eaves.
I went to Harbor Freight and got this Avanti paint and stain sprayer:
avanti_paint_gun.JPG.​
I was pretty pleased with how well it works.
Finally got rid of the artwork the previous owner's grandson left a decade ago.
I didn't paint the plywood square because I plan to reinstall an air conditioner in that opening.
Goodbye pink paint!
I finally got the whole thing trimmed and painted. I repainted the black trim around the doors and the front window.
It's actually a decent looking building now. Next spring I'll landscape around it.
I removed the old air conditioner and closed the opening until zi can get a new one. I just need to make the old one go away.
That pipe next to it is for a propane furnace mounted along the inside wall. I'm getting rid of the old furnace but haven't decided if I'm going to put anything in it's place.
I want to pour some concrete aprons in front of the doors on this side.
I repainted this door and repainted all of the handles and deadbolts black. This door has a combination lock.
I have to build a step here. I'll probably build one out of cement and block later this year.
I don't have any electric in the shop yet, so I found a pair of these solar powered motion sensor security lights on Amazon for $36 and mounted one over this side door, and one over the barn doors on the other side. I'm surprised at how bright they are and how well they work.
I've been having problems with a mole digging tunnels all over my front yard.
I put some mole killer in the tunnel. That didn't work. I sprayed a 'deterrent' on my yard. They laughed at me.
I finally had to declare all out war and bring out the heavy hardware.
I bought this Scissor Trap / Mole Trap on Amazon because I couldn't find any stores that stocked it:
After I choose my spot, I pressed the raised dirt from the tunnel down with my foot, and then stuck the trap in the ground. When you set the trap, it opens up a pair of scissors. When the mole digs through the dirt it pushes up on the trap which triggers it.
I set the trap again just in case it has a partner in crime down there somewhere.
Finally nabbing this thing after months of trying to get rid of it made me feel like that was the best $26.00 I ever spent.
Damn you do nice work. I'm sure the neighbors are happy too.
You even got the varmint. I've never had any luck with that.
Glad your foot is ok. That could have been serious. I would've gone straight to the doc's or a shot and then straight to the bar for another.
