sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
Doing a bit of reading today, I've struggled to find the 3.08 gear set being used with an LSD carrier in the 7.5. Short of having all the parts in my hand to compare, does anyone know if the LSD carrier will even work a 3.08 gear set?
I seem to remember SN95 mustangs having LSDs and 3.08 gear sets, but I'm having trouble confirming.
As far as I know, the only difference in an open carrier and an LSD is the guts in the carrier. The part where the ring gear bolts to should be the same. At least it was on my '98 with the 7.5. Since you already have the carrier, clearance for the tone ring (if you have one) will be a nonissue since the carrier will already have the relief for it.
