5R55E FILTER QUESTIONS
dvdswan
Seattle, WA
So I'm looking up 5r55e transmission filter and gasket kits for my 02 Explorer 4WD (trans code R) and 02 Sport Trac 4WD (trans code D), both have the 4.0 SOHC. I want make sure I'm ordering the correct filter set for each. I know through researching the forum and google the ST has a Ranger drivetrain and the trans code D is the 5R55E, but can not find out what trans code R is, maybe the 5R55W or 5R55S. @RonD stated in my thread when I bought it that it was a 5R55S. But I can't find anything definitive denoting what model transmission it is. So, any help would be grateful.
I can't see why there would be a difference between RWD and 4WD in regard to the trans filter but I'm finding stuff that points otherwise. Why is this?
So, which filter for each vehicle?
I can tell you that 2wd vs 4wd is different. 4wd trucks had a deeper sump trans pan and the taller filter.
Count the bolt holes
And +1 ^^^, 4WD transmissions have a deep pan so filter sits lower
Makes sense with a deeper pan. It seems silly why they would do that, just have a deep pan for both. So, the S and W models have 16 and E models have 18. I didn't think to count them. Thank you both. @RonD and @snoranger
So, which type is better for the pan gasket: cork gasket or paper?
I prefer cork gaskets in general because it swells to fill gaps when wet
I have used LubeLocker gaskets in the past with good success- they are a paper/rubber, aluminum core (hybrid? not sure what to call it) gasket with a ring or two of silicone? rubber on either side. Have one on my diff right now and one used on the trans of my previous ranger w/ no leaks.
