- Mar 24, 2013
- Age
- 81
- Renton, WA
- 02 2X4; 08 FX4
The fuel tank capacity is listed as 19.5 gal. What is the actual useable fuel? The warning light comes on at around 16 gal.
My 2020 officially holds 18 gallons but I've filled it up with as much as 19.2.My light comes on about 2 gallons from empty. So somewhere around 36-38 miles of lee way. I never intentionally push it.
As a guess, since I've never ran it until the engine quits or even came close, is some where around a gallon of fuel left, the pump will start cavitating and you'll be running on what's left in the fuel line.
It won't go anywhere when its empty unless it's downhill or being towed.Every vehicle could be different. Probably atleast 19 gallons usable.
Better question is what is the "reserve" after you hit enpty. AKA how far will it go on empty? Best way to find out is throw a gas can in the bed, let it hit E, then drive till it runs out. My 99 will do right at 30 miles after it hits empty, so about 2 gallons in reserve. Again every vehicle is probably different.
Better than my F-250 atleast. It doesn't have a reserve, it runs out at 1/4 tank. Something wrong with the sending unit in the tank, but since it's got a 26 gallon tank and will do better than 300 miles before hitting that point, I haven't bothered trying to fix it yet.
Most likely the pickup "foot" at the end of the tube. They are notorious for deteriorating and falling off. Leaves the tube about 2-3 inches above the bottom of the tank.Better than my F-250 atleast. It doesn't have a reserve, it runs out at 1/4 tank. Something wrong with the sending unit in the tank, but since it's got a 26 gallon tank and will do better than 300 miles before hitting that point, I haven't bothered trying to fix it yet.
The guage on E means it's low, it's empty when it quits running, the gauge can show E when there is 3-4 gallons left.True, but hits "E" empty and runs out empty can be two different things. Never know what might happen, so I like to know how far I can push it. Also that's why I said put a gas can in the bed, that way you can get back to the gas station after you run it out. Didn't think I needed to specify putting gas in the can before attempting this.
