poomero
What are the benefits of swapping to a manual transfer case from an automatic transfer case? I’m asking because I have a line on a free manual one from my 95 4.o 4x4.
The E-shift motors aren’t as reliable as a pull handle.
Most people will say they let you down when you need them the most, but those are the same people who don’t use it regularly. They just ignore it until they need it and hope it works.
Yes, reliable is the BIG BIG deal
Also has Neutral if Flat Towing is ever needed
You should also change to Manual Hubs
To put it in another perspective. If you had to jump out of a burning airplane, if you can't have both, which ONE of these would you choose to have:
a) a barometric monitoring electronic automatic parachute opener made in an unspecified third world country; or
b) a ripcord.
Reliability has its advantages.
Mine has manual hubs already.
Why?
............................because the "auto hubs" failed or were unreliable![]()
Manual hubs are a good thing. Still need periodic maintenance. But much more reliable.not sure why to be honest. I thought it was standard because when I got the truck last year it had them already
They would not have put manual hubs on a electric shift transfer case system. That gets rid of the "one touch" 4x4 system theory.not sure why to be honest. I thought it was standard because when I got the truck last year it had them already
The shifter assembly is the hard part to come by when people do the manual t case swap... since they're mounted to the transmission a lot of people end up scrapping them which is annoying...
If working I could go either way, but if it's free it wouldn't be bad to keep the parts around! If you don't have room I could meet you and figure out a place to store one in my mess... not that I need another spare but...
