INFO Photos of different wheel/tire sizes on stock and lowered 2WD's
HERE is my wheel swap w/ pictures.
Ok everyone.
Post up picks of your stock or lowered 2wd's with non-stock tire sizes. Indicate the tire size, rim size, backspacing (if you know it), and how much drop you have if you're lowered.
Lets build a reference to help out others trying to figure out what size wheel/tire they can fit.
Thanks! :icon_thumby:
Very smart, Jim. Choosing the right wheels and tires is maybe the most economical way to upgrade your truck.
Mine is a 2003 Ranger 2WD Edge. I lowered it by one inch for improved handling, easy loading and unloading, also so my wife could get in and out more easily. I bought 15" Pro Comp wheels, Tires are Cooper Discoverer AT3 (all terrain) 265/70/R15 or in inches: 29.6/10.4/R15
  • Photos of different wheel/tire sizes on stock and lowered 2WD's
Changed rims this Xmas. 15x10 AR Torq-Thrust rims with 3.77" backspacing. Tire choice this time was 275/60/15 BFG T/A tire. I'm on stock suspension, no rub at any point so far. Love the ride, very smooth. I've always wanted a set of T/A tire, such a classic look and even did the white letter out. Damn what ever happen to cheap tires anymore, tires where more than the rims!!!! Still like the set, great 55th Bday present to myself.
Edit..Crazy how that pvc pipe mounted on the wall makes it look like I got a huge L" shaped scratch on my passenger truck bed. I saw that and had to go look....
Those are a favorite wheel of mine. They just say muscle
I agree, only thing I had a little trouble with was deciding between 275/60 or 295/50. Either was cool with me, I choose 295/50R15. Thanks
2019 Ford Mustang Ecoboost Wheels 17x7.5's with Hankook 235/55/17's.
I know this is an old thread, but did you use any spacers on these wheels? If so, what size to push them out? It looks like those are 17x7.5 +37.5mm offset. That wheel and tire size looks perfect for a slightly lowered daily driver.
that thing is even raised up to clear the wheel housings. :stop:
I geuss i never put pics of my 04. Stock wheels, flipped rear mounts, removed factory 2 inch lift block in back, and lowered the bars out front all the way down
1997 2WD on stock chrome 15x6 Ranger Splash wheels and 235/75/15 tires, no modifications at all, they bolted right on.
Stock tires were 225/70/14
So I did a thing today. Got some new shoes for the danger Ranger. BFG K03's and the ride, stance and feel is 10x's better.
Didn't specify just rangers. Steelies 14x6 with 195-60-14 .The other wheels on same truck are 18s with a 18x9.5 with a plus 38 offset on the rear and 18x8.5" with a plus 20 offset on the front. Lowered 3.5"s in front djm beams. And flip kit in the rear with helper springs because rear sat lower then the front. 1987 2wd Bronco ii is sitting on powdered coated 99 mustang wheels 17x8 with a plus 30 offset with drilled out center caps in the front to clear the grease cap. 245-45-17s tires . Lowered the front with chassis tech 3" drop beams and 2" drop springs lowering the front around 5"s.And flip kit in the rear with C notch that lowered it about 6" in the rear.
Didn't specify just rangers. Steelies 14x6 with 195-60-14 .The other wheels on same truck are 18s with a 18x9.5 with a plus 38 offset on the rear and 18x8.5" with a plus 20 offset on the front. Lowered 3.5"s in front djm beams. And flip kit in the rear with helper springs because rear sat lower then the front.2wd Bronco ii is sitting on powdered coated 99 mustang wheels 17x8 with a plus 30 offset with drilled out center caps in the front to clear the grease cap. 245-45-17s tires . Lowered 5"s in the front .And flip kit in the rear with C notch that lowered it about 6" in the rear.
That B2 is epic. I'd drive the pants off it.
