- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
Not sure exactly where to put this.
Anyways...some of you know about my LTD II/351W adventures in my build thread.
The engine in the car ran good...20 years ago. Untill the timing chain slipped and bent valves, etc.
I have the engine out of the car...and im up in the air with what to do.
Original plan was to regasket it, get the heads/manifold decked, clean it up and run it.
Then i got on the kick of rebuilding it.
I called my local machine shop. I got a quote of around 300 bucks to do a hone, hot tank, and cam bearings. Very reasonable and my gut tells me thats all itll need.
I went down the rabbit hole of line honeing/boring. Now full disclosure i dont want a 1500 dollar surprise if i tear it apart and take it in.
So what im reading is a line hone/bore is absolutly needed on any rebuild, some say dont worry about it, and some say its really only needed on high HP builds, which this is not. Its a stock, maybe a bit more, rebuild.
Ive done assembly and disassembly when we used to work on the mud trucks but i never dealt with machining. I was basically handed parts and told "put this togther" lol.
So im curious....what are the chances this will need to be done...should I have it done....or am i thinking way to much about this?
