Jim Oaks
Just some guy with a website
Founder / Site Owner
Administrator
💻 TRS Socials
TRS 25th Anniversary
- Aug 2, 2000
- Age
- 58
- Nocona
- State - Country
- TX - USA
- Other
- 2005 Jaguar XJ8
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3L EcoBoost
- Total Lift
- 3.5-inches
- Tire Size
- 295/70/17
LED Lights & Winch:
With the bumper built, I added a Nilight 30-Inch Spot/Flood LED lightbar to the top of the bumper. This is a PRO series lightbar and has a built-in EMC that limits EMI/RFI interference. This light uses Osram P8/5W led chips for a total of 240 watts per light, with lighting performance 24800LM/PC, 6200Lux@10Meters, 1Lux@787Meters (2582FT).
This light bar comes with a wiring harness, relay, and switch. I will be using my own switch.
The fog lights are Nilight 4-Inch Fog Lights that also came with a harness. Again, I will be using my own switch.
When I added lights to the Loan Ranger I worked them off of a wireless remote control instead of running wires in to the cab. I re-used the remotes and modules on this build so I could use the lights until I added switches. I will keep the remotes installed when I add the switches. Not only are the remotes handy (I can hold it in my hand driving country roads at night to quickly turn it on and off), but they also have buttons to make the lights flash. The top button flashes the SOS signal. The bottom button has different flash patterns that you change buy pushing the button. With these hooked to the fog lights, the fog lights can quickly become warning lights.
I added Nilight 4-Inch LED light pods to the side of the push bars. These are a flood pattern lights and pointed to the sides and slightly forward. They will be added to individual switches so I can see off to the side at night if needed.
The winch is a Smittybilt 97495 XRC GEN2 9.5K Waterproof Winch. It's a 9,500lb waterproof winch that I had left over from my car trailer.
Bed Tie Down Hooks:
My 2021 Ford Ranger FX4 XLT didn't come with bed tie down hooks in two of the rear locations where they were on my 2019 Loan Ranger. For some reason these things are stupid expensive to purchase. I found a pair of them on ebay new for $50.00. CLICK HERE.
I like these tie down locations because they allow me to secure water and fuel cans in the corner of the bed.
Below is how my can's were secured in the bed of the 2019 Loan Ranger. I did that Trans America Trail with this can secured like this and it never came loose.
Bed Tie Down Hooks:
