Thanks all. The auto trans vent, I can get my hand up in there and feel that it's a rubber connector to the trans that connects to the steel line going down. So you bypass the existing metal line, it can stay there I guess.
Is there any concern about the loop in it, re:
The metal "loop" tube is to condense any ATF vapor that may come out and let it run back into trans once it condenses, so no "oil drips" from the end of the tube
I would think a longer rubber tube would serve the same purpose. I don't think I need to worry too much about liquid from trans coming up through breather, it could, I suppose, but doesn't seem likely.
Should be able to route the hose from the top of the trans to a good place without having to deal with it being close to exhaust/front driveshaft, Right Eric?
If there's potential for odors maybe engine bay isn't best place for the front ones, putting them all between the bed and cab sounds good (what Eric did).
And you (Eric) have 3 but there should be 4 for me, you have one less because of manual trans.
I'll check out about sealing at the other locations and fan and etc. Seems like that's getting up higher, don't know if I'd ever be in that deep but definitely worth checking those things out.
Ford says manual hubs are sealed, they shouldn't get water in them... yeah Milemakers have o-ring, whether they are waterproof on the outside I dunno.
Think is if you thought they were wet seems like you could just take them off and put in the sun a while. And I suppose they can be taken apart.
