racsan
⭐Supporting Member
- Aug 17, 2007
- central ohio
- 2.5 (4 Cylinder)
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
I put escape rims on the butt today, both spares for the escape dont want to hold air so I broke the beads, cleaned the rim & tire surface and then put some oil on the bead surface of the rim before reinflating. Figured Id drive it a couple of days on the ranger and see if they stay up. Doesnt look horrible, I used 2” spacers to correct for the positive offset of the escape rims. Put them about where they should be. Tire size is 235/70/16” so not much bigger than when I run the 235/75/15’s. Put my gps in so I can see how accurate (or not) the speedometer is. Wouldnt want to tow or haul with this setup but it should be ok to get to work and back.
Those 9” drums sure look tiny inside of a 16” rim!
