I am sure the Cam sensor could cause rough idle but it shouldn't.
4.0l OHV engine was used from 1990 to 2000 in Rangers
Cam sensor was added in 1995
1990-1994 ran just fine without it
It was added for Sequential Fuel injection and to lower emissions
1990-1994 ran Batch Fire injection
The CRANK sensor is what times the spark and fuel injectors, the Cam sensor was added to refine that timing since it rotates 1deg for each 2deg of crank movement, but not to over ride it.
If Crank sensor pulse doesn't match Cam sensor pulse then Cam sensor pulse is ignored, and computer sets a Cam sensor code.
If Cam synchro was 180deg off then pulse would match crank sensor but injectors would be 180 off
This is why compression stroke TDC is so important
