Changing Tire Size / Splash Screen / Fog Lights With Headlights Using FORScan
Jim Oaks
Just some guy with a website
Founder / Site Owner
Administrator
💻 TRS Socials
TRS 25th Anniversary
Nocona
TX - USA
Other
2005 Jaguar XJ8
Vehicle
Drive
2.3 EcoBoost
3.5-inches
Changing Tire Size With FORScan:
In order for the speedometer to read correctly you need to change the tire size programmed into the Ranger.
First go Forscan and download Forscan for your computer:
Download FORScan
Then sign up for a 2-month free extended license key:
Support Request (forscan.org)
When you run Forscan on your computer click the 'about' icon on the lower left that looks like a steering wheel with a question mark. This is where you'll enter the license key that Forscan will email you. The key will be a file that you download. To install the key you'll click a button which will bring up a window where you'll click on the file you downloaded.
index.php
You'll need to go to Amazon and order this OBDLink EX FORScan OBD Adapter:
index.php
When you get the adapter and plug it in to your laptop (I have Windows) it will load the necessary driver in to your computer.
Now you just plug it in to your computers USB port and the OBD port on your Ranger.
Turn the key to the on position and click the 'Connect To Vehicle' icon in the lower left part of the screen.
index.php
I don't remember where I got this when I first used it, but you'll see a message about switching to real mode. Click Yes.
index.php
You'll get a window pop up telling you to make sure your key is in the ON position. Click OK.
index.php
You may also get a message telling you that the software in your adapter isn't up to date and it will update it. Click to allow it to update and make sure you have an internet connection to do so.
While connecting to the truck I got this warning message telling me that my adapter was not optimized for maximum performance and asked me if I wanted to improve the baud rate. I chose No since there was a warning that it may not work on some adapters. I may check Yes in the future.
index.php
When the vehicle is connected the 'Interface' and 'Vehicle' indicators in the bottom left will glow green instead of red.
Click the 'Configuration and Programming' button (3rd button from the bottom in the left column). This will load up the modules.
index.php
Scroll down to the BdyCM Body Control Module and click on it. Then click the 'Run' arrow button at the bottom left. That will load the module.
index.php
Scroll down to 'Tire Circumference mm' and then click the 'Edit Selected' button.
index.php
A window will open and allow you to change the tire size in mm (millimeters).
If you need to know your tire size in millimeters, go to https://tirecalculator.com
For me, https://tirecalculator.com/295-70r17-tires tells me that my 295/70/17 tires have a 2656 mm circumference. However that site says that tire size is 33.3-inches in diameter and Thunderer says that my tires are 33.5 inches in diameter, so I used https://tirecalculator.com/285-60r20-tires because that tire is 33.5-inches which has a circumference of 2669, but the speedometer read 3 miles an hour too fast, so I tweaked that number down lower.
Anyway, you can see where I had already changed it to 2669. I'm going to change it to 2656. Once you change it click the check mark button.
index.php
To get it to actually save you need to click the 'Write' button that's next to the 'Edit selected' button. It will ask you to confirm your changes. In the pic below you can see that I'm changing from 2669 to 2656. Click the check mark button.
When you do this you'll hear a click in the dash and you'll see the radio display screen blink.
index.php
A new window will pop up and tell you that the block has been programmed successfully and to turn your ignition off and then back on. Click the Ok button after you've done so.
index.php
That's it. The tire size has been changed. Take the vehicle for a drive and check the speedometer against a GPS. If the speed is off, you can adjust the tire size. If your speedometer is reading to high, make the tire size smaller. If the speedometer is to low, make the tire size larger.
Making The Driving Lights Stay on With The High Beams Using FORScan:
Some people call this Bambi mode. I have no idea why.
Again you'll want to be in the BdyCM Body Control Module.
index.php
This time you'll scroll down and look for 'Fog lights if High Beam is on'. The factory default is Disabled but you'll see where I have already enabled it in the pic below.
index.php
Click 'Edit selected' and a window will pop up to choose 0 - Enabled. Once you've chosen that click the check mark button.
index.php
Once you've done that you'll have to click the 'Write' button to save it. A window will pop up asking you to confirm your changes. Click the check mark button.
index.php
You'll hear a click noise in the dash and the radio display screen will blink on and off. You'll get a message asking you to turn the ignition off and back on. Then click the 'Ok' button.
index.php
That's it, you're done.
Changing The Splash Screen With FORScan:
This is the screen that comes up when you first turn the truck on. The default is the Ford logo.
I changed mine to the Ford Performance splash screen.
index.php
This time you'll be looking for the APIM module. Click the APIM module and then click the Run icon in the bottom left of the screen.
index.php
Once it loads, scroll down to 'Splash screen' and click 'Edit selected'.
index.php
You can scroll down through the options. I did not want to be a poser and choose the Raptor splash screen. I went on down and clicked 'Ford Performance'.
index.php
Then clicked the 'Write' button to save it. A window will pop up asking you to confirm your selection. Click the check mark button to save your choice.
index.php
index.php
Are you gonna have this equipment with you at the roundup? I jad abuddy change my tire size but since I've went up I'm back off by a few mph. Then he sold his F150 with the Rough Country thingy that changed it.
I probably could. I'd have to sign up for another free extended license.
If not no big deal. I just watch the GPS speed on my navigation app right now to make sure I'm not speeding. Plus I can't decide on what tire size I'm running haha. From 255/65r17s to 255/75r17 MTs (which is what my speedometer is calibrated for) to 305/65r17 MTs and just got a set of 305/70r17 Toyo Open Country AT2s from a friend with about 60 % tread he pulled off his Power Wagon I'm probably gonna squeeze on there unless I trade them off before I need them haha.
Was there an option to load a custom image for the splash screen? Or are you stuck with their list of pix?
I also originally set the tire circumference to the actual according to the manufacturer and it was overkill and the speedo read too high versus the GPS. For my 265/70-17's setting it at 2400 was spot-on.
More light to help you see deer at night, aka "Bambi".
Nice write-up, thanks.
