2.5L ('98-'01) Ranger 5spd NoCrank-Remote Starts Only
MotorBoater
Grandson of Harry Bennett
Firefighter
Tacoma, WA
2.5 (4 Cylinder)
Hey everyone, thank you in advance for any help or support you can give.
98 Ford Ranger XLT 2.5l 5speed
I've added some features to this truck since i've had it, including installing A/C (not yet wired up b/c truck won't start so what's the point), back up camera, double din stereo, upgraded ALL exterior lights to LED, went from stinky old fabric seats to nice leather ones, rear leaf springs so it doesn't squat anymore.
Ive had to install a new clutch, new starter (broke doing clutch job) and that was about it until...
I was driving one day and the truck started misfiring one day while i was idling parked. I got it to get going again but it broke down a mile away from where i was. i was stranded for HOURS trying to figure it out, couldn't. somehow it fired up, dunno why. it drove for awhile after that until it didn't. I've done the Power Distribution box 2 times already and wired it back into the harness, the reason I had to do this is because there was a couple broke lock tabs so when i was checking the fuses and putting them back into the box they would push the wire down and fuse wasn't making good contact. the first time was kind of practice but the second time I got better results. Still no crank no start, but all lights, windshield wipers, stereo, horn...all the other stuff works. Battery says 12.24v and its a new Optima Red Top.
I have Chilton and Hanes manual but when it comes to these wires Im so lost in a needle in a haystack. I need help :(
Check the simple stuff first.
Hows the battery cables look?
Are you sure the new starter didnt take a shit?
Honestly if it were me, since you have a 5 speed, i would try to pop start it and then you might have an idea if its just in the starting system or something deeper.
@rusty ol ranger all the battery cables are good condition, I just learned I could possibly pop start it earlier tonight, i'll try tomorrow. New starter cranks when I Arc it
Yeah try to pop start it and see what happens.
Let us know
So I've continued to do some research online, i'm thinking the Crankshaft Positioning Sensor or maybe the ECU? What do you guys think....when the truck first started to have this problem I was parked for awhile with the engine running. So maybe the heat from the motor just really took a toll on it.. I'm just racking my thoughts on this one.... I'm about to offer a prize for whoever helps me diagnose this thing lol $$$$
The crank sensor wouldnt keep it from cranking.
Not sure about the ECM on a 98. If it dont have PATS i wouldnt think the ECM would stop it from cranking
Is this really a problem that it would crank?
I read it as it will crank but won't start...
yeah it doesn't have anti theft or anything like that, but I have (so I thought) lightly washed the engine bay when I go to the car wash...thought possibly I could have gotten it wet if there was a bad seal or something.
Engine is NOT turning over, therefore not starting. Everything beeps as normal when I turn the key, including the *click from the relay
98 should have the starter solenoid on top of the starter correct? You also said it will crank if you arc the starter solenoid correct? If that is the case you need to check voltage at the small signal wire at the starter solenoid with key on.
Clutch in and key in start position.
To make this a little bit easier for everyone to see what's happening, I'm going to try to post an introductory walkaround video on youtube and post it here. Just so everyone can be on the same page as me.
I see now the no crank in the title...
I see in the body of the message that it was running bad and while driving it quit you got stranded. But it started...
If it truly won't crank... meaning when you turn the key it won't crank the engine... that is most likely not related to the engine running poorly and quitting while driving.
You need to diagnose the crank issue first... then the drivability issue.
That's why I was kind of thinking Crankshaft Position Sensor and possibly the ECU.
I'm headed to the auto parts store to grab a code reader and see what that will tell me
around those years Ford started using a system called PATS, don't remember what the acronym means but it's just a chip in the key, if your key looks like the one in THIS link then you do have anti theft, if the plastic part is smaller and the ring slot is centered then you don't have PATS, not all 4 cylinder Rangers apparently got PATS, and I wish my Explorers didn't have it...
I would definitely start with the no crank situation, the start signal goes from the key switch to the body module to the starter solenoid so either there is a problem with key power getting to the module (I believe it's a separate circuit from the power to the multifunction switch from the key) from the key or it's power or ground... unfortunately I only know enough about that system to know it's there and does some stuff not how to troubleshoot it...
