- Aug 25, 2016
Been in piping industry for almost 16 years.. tape male fitting and put a lil dope on after... Just like condom then lube
What kind is it? Tractor supply or ace should have one.I drove it to Lowes to get a new chain for the chainsaw, but they were out of stock. I'll have to figure out who makes this particular model of Craftsman chainsaw and track down a chain that will fit.
Pictures or it didn't happen hahaAlmost all Craftsman saws are made by Poulan if that helps any...
Just got back from taking the '90 Ranger wheeling in Christmas Valley Oregon again... went well, only one Ranger related snafoo... had a passenger and we were doing some spirited dune running and over one spot there was a loud BLAM and a shattering noise... one of the slider panes exploded... turns out the passenger seat back (Explorer buckets in a '90 regular cab... not enough room...) had been rubbing over the years and wore through the material to metal, looks like a while ago but hasn't been an issue until we hit just the right bump with just the right sized guy in the passenger seat. I'll have to grab one or two next time I hit the yard on half off weekend... for now I'll put in the lexan slider I made for the last window that that seat took out a decade ago (just changed the window in 2020...) Other than that the power steering seems weaker than it's been but I haven't checked the fluid level yet... the radius arm bushings are toast but I just need to build extended arms to fix that and other stuff...
View attachment 84195all cleaned up. Have to admit it's the first time it's been cleaned up since before I met Eric on the Traverse. Poor thing
Kenda Klever MTs 255/75r17What tires are those?
Do WURK !!!Loaded it up well over max GVWRView attachment 84293
