- Aug 17, 2007
- central ohio
- 2.5 (4 Cylinder)
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
Well it looks like its time for the dreaded job of changing out the hot water heater. I knew from the looks of the outside of it that it was on borrowed time when we moved here last fall, seems to be electrical rather than ruptured but given the signs of slight leakage at the thermostat covers Im going with a whole new unit. What odd is 2 things: The in/out (cold/hot) hookups are on the side, and theres some sort of pressure valve on the cold side. It does also have the conventional pressure relief valve on tank exiting through floor. Its a electric tank, 40 gallon on well water, there is a softener so I don’t understand the corrosion, this tank was new 5 years ago according to the previous owners. Im thinking of going to a conventional top hookup instead of this side crap, Not sure if I can axe that valve on cold side. There is no pressure tank like Ive seen on most well systems. Tank is draining right now. heres some photos of it.
