- Nov 13, 2018
- Canaan
- State - Country
- NH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
I think we're saying about the same thing in different dialects. Ford called them hard faults and they didn't need to repeat to set, memory codes would be set if a fault occurred intermittently and stay for a set number of key cycles before clearing. Both would be set by a single occurrence and both should appear if ear by flash out. I think by 94 you'd have 3 digit codes, 111 10 111 is all pass, hard faults would be first, the the separator "10", then whatever memory codes. Some aftermarket scan tools would also display their guess of the most likely cause instead of just the codes. We fixed many vehicles from independents who followed their scan tool's instructions repeatedly before bringing their customer's cars to us. If it doesn't set a code, it just means whatever is wrong is within range- the first bunch of 2.9 Bronco II's we got ran like crap until we figured out there were 2 wires reversed on the TP sensors. Instead of about a volt at idle, they showed 5 volts, instead of 5 volts at WOT, they showed 1 volt. Some weird stuff used to get produced right before a new UAW contract was signed, not that they'd possibly deliberately sabotage vehicles, they were just nervous about the new contract. Is there a "wink-wink" imoji?As a mechanic for 15 yrs professionally, what I need to know isn't solved by flashing the MIL/CEL for a code number, which isn't there as it hasn't had enough warm up cycles to set any hard codes (tech speak for codes that have happened on more than one drive cycle and have gone from the industry standard "pending" to the industry standard "stored") What I need to know can only be found by access to live data as the vehicle is running. The flash method, in my experience, doesn't ALWAYS tell you ALL the codes.
Yes, I have actually flashed the MIL/CEL, and then gone behind it with a scan tool, and gotten more codes, and a more complete story. Not sure how many members remember me from a decade ago, but I am a Ford Certified Tech, not a backyards parts changer.![]()
