- Sep 21, 2007
- Wa, Bremerton 98310
- State - Country
- N/A
- Total Lift
- Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
- Total Drop
- Ranger 5sp, BII A4LD
- Tire Size
- Ranger 32"/4:10LS, BII 33"/3:73LS
- My credo
- Deengineer until it is how Blue Oval should have sold it!!
fordwheelinman,
I had one of these engines, I rebuilt it, only put about 5k miles on it, then it sat for 8-10 years. When I decided to use it the lower intake manifold gasket had been compromised, as I understand due to dissimilar metal corrosion between the the iron block/heads and Al intakes.
It ran and i was able to verify the timing but had a miss. I located a small coolant leak from the top of the engine, I then inspection the lower intake manifold gasket, I found the gasket compromised front and back, just above the coolant galleys.
