abs speed sensor shield kit
Ed C
Groton Ma.
1995 ranger
Hi, Can anyone tell me where i might find a front abs speed sensor shield kit for my 95 Ranger. Also heard it called abs heat sink kit. Part no. is F3TZ2D204A. Part is discontinued. The front abs sensors go through these shields. A small " block" of steel that bolts to the spindle assembly along with the abs sensors. I would buy used if i could find them. any help is deeply appreciated
I am familiar with the part. I would suggest picking them up at a local junkyard or looking for someone parting out a truck on facebook marketplace that is willing to ship them to you. Any idea what size bolt holds them on to the knuckle ? From my research it seems to be a 6mm 12 pt , but mine seems to be a hex head. in the picture below the abs shield can be seen painted red:
68944
Hi Sebastion 323, I finally found the parts on a 95 ranger farm truck. Thanks for the help
i am actually stuck taking this ABS shield part of my truck right now. any idea what size the bolt to remove it was ? Mine is very rusted and want ot have the exact size so I don't round off the bolt head
I used an 8mm socket on mine, but they get so rust corroded that your best bet is to hit them with pb blaster and pound the closest fitting socket on. Good luck. Ed
