- Sep 14, 2007
Just Randy - This program rocks.......
Says I should get around 171hp@4500 and 223ft/lbs at 3500
Yeah, its not bad. I've been using it a lot on atv engines lately. One thing I can't figure out though.... according to the software, webcams camshafts for the LT230 actually LOSE hp across the board when compared to the stock cam. I've been scratching my head on that one for almost a year. Everybody that runs the cams say they rock, but nobody has ever replaced JUST the cam. They always install a big bore kit and a bunch of other stuff too. Hard to believe someone that's been grinding cams as long as they have are wrong, but the software works on all the other aftermarket cams.... The only thing I can think is the software doesn't consider the stiffer valve springs. But that's the only issue I've noticed.
The program is pretty accurate though if you can get your hands on the real flow numbers for the head.
