Wanted Shift linkage
ThatOneGuy
South sound
Let the universe take you where it will !!!
Shift linkage for 1350 manual transfer case, for an m50d/a4ld
In my case the one from my FM146 worked too. Just to give you another option for a hard to find part.
The A4LD linkage is different from the FM145/6 and M5OD
We ( @85_Ranger4x4 )went over this a on another tread a week or two ago. I’m open to learning so here we go. I see there are at least two different shapes. One being 90degree dog legged and the other being just offset. The question being are they interchangeable. I have one of each in the barn all on vehicles they came with.
89 original FM146 swapped to a M5OD. Shifter from the FM146
85 A4LD
85 FM145
Both the 146 and A4LD are the offset type the FM145 is doglegged.
Enlighten me.
Look at the lengths of them.....
Plus, the A4LD linkage actually says “A4LD” on it. It looks similar, but is in fact different.
The C5 linkage (very rare these days) is close to the FM145 but is a different length as well.
Measured from end of fork to pivot bolt
FM145 =3”
FM 146 on M50D = 5 3/8
A4LD =5 3/8
89 original FM146 swapped to a M5OD. Shifter from the FM146 View attachment 67957
85 A4LDView attachment 67958
85 FM145View attachment 67959
Enlighten me.
Slightly off topic, can you tell me what your kickdown linkage looks like on the 85 A4LD?
Kinda hard to describe but I can get a picture. Looking for over all or ends?
Over all, basically is it a rod that connects to the carb and has some bends in it, or is it a cable through a bracket?
It’s a rod. I’ll try to get you a picture.
A couple pix on the truck and I have a spare so an over all too. Do you need one?
