How do I check epc pressure at the port ? 2001 ranger 3.0
Burnsy
Hudson fl
ive been dropping the pan, adjusting the epc solenoid to eliminate the flare in my tranny. I've eliminated it but went too far with initial adjustment and have since been dialing it back. I've got it running pretty nice right now but I want to test at the epc port as I've come across info showing what the pressure(s) should be depending on idle or open throttle etc.....I can't find any videos on YouTube showing how to test at port specifically. What measurement device do I use and how ? Thanks
Second page here tells you where the 2 ports are and what pressure range you should see at idle and at WOT(wide open throttle): https://atracom.blob.core.windows.net/gears/2003/2003-05/2003_5_50.pdf
You just need a helper to press gas pedal to the floor and release it, not hold it down all the way
The wheels need to be off the ground of course, as the tests are done "in gear"
You need a pressure gauge that can go up to at least 400psi, 500psi is better, and the hose with correct fitting for the transmission
Use 4R44E 3.0l numbers
Thanks guys, im smart on some stuff and oddly challenged on some stuff you think id be smart on.........so.......what am I measuring from the epc port ? Fluid ? what is the port fitting ? Special fitting ? What is it called ? where would I get the proper tools ? Auto store ? Home depot ?? .....thanks
I was just gonna do it by myself just the idle/idling test
The ports are identified in this document also...
@RonD I don't see your link sir.
Thanks uncle grump, that link you shared was originally posted by myself. Good stuff in there. I've seen the location now. .............the cashier in the gas station called me Mr Grumpy yesterday 😀
That was you that posted that originally.
Gump Grump... it kinda depends on the day. lol
